Old 10-11-2008, 04:52 AM
capriceforever's Avatar
capriceforever capriceforever is offline
1996 Silverado Won't Start
Over the past few months my 96 Silverado (5.7L, 90000 miles) has gotten steadily harder to start. Sometimes 2 tries, than 3, than 4.... Finally a dozen tries and now it won't start at all. Truck runs great once its running, it just doesn't want to start.
Ignition system fine, good spark. When I take the air cleaner/intake off and pour an ounce of gas into the manifold, it fires up immediately and runs great. But if I let it sit more than an hr, it won't start. Have to pour gas down the intake.
When you put the key in the on position, you can hear the fuel pump start whirring for about 2 secs, than goes quiet, so fuel pump relay seems to be working.
Any thoughts here before I start wasting money? Much appreciated.
Old 10-12-2008, 10:49 PM
hookeartool hookeartool is offline
Re: 1996 Silverado Won't Start
sounds like it is your injectors if u poor gas and it fires right up, but it mont when u just try to start it without
Old 10-13-2008, 12:21 AM
Bought a fuel pressure gauge. Pressure before start-up is only 53psi. If you turn it on/off a few times, you can get it up to about 57. But it should be over 60psi, so tomorrow I'll be replacing the pump. Hopefully its that simple.
Thanks
Old 10-13-2008, 12:40 AM
Scrapper Scrapper is offline
AF Premium User
i don't think it's your pump if you hear it zing right up that loss of fuel presure is not that much. have you cganged fuel filter? it does sound like injector problem.
Old 10-14-2008, 11:18 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
Check the fuel pressure regulator first before blowing $$$$ on a pump. A $40 part located under the plastic intake cover on the rear of the injector spider assembly.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-23-2008, 09:56 AM
BOZZZ BOZZZ is offline
I would say fuel pump. Vortec engines are very picky on having the right pressure to get started.
Old 10-23-2008, 10:35 PM
j cAT j cAT is offline
I believe that he did replace the fuel pump as he stated the pressures were too low...
