1995 Chevrolet Silverado 1/2 ton possible rear axle problem?
My silverado makes a LOUD clunking nose from the back. When drivng it makes a sudden stop. I dont know what it is, I asked a few people and they said it was the rear axle? If so what part or how would I fix it. Need help fast, I use this truck for work everyday! Thanks.
Re: 1995 Chevrolet Silverado 1/2 ton possible rear axle problem?
If you have the g80 limited slip....look for that on the RPO code in the glovebox....Def get that looked at....It could be ready to take a dump.
2004 Silverado Half-Ton Crew 7-9" Cognito Lift (set at 8" right now) Betts 7" rear springs w/factory block 3" PA Body Lift Yukon 4.88's with Auburn LSD Xentec 6500k HID lows, Silverstar Ultra brights Wade in channel window vents Covermaster Top Flowmaster 40 series, dual outs Nelson 89/91 HOT TUNE 20" MB Gunner 6's, 37" Toyo Open Country MT's Eclipse AVN6600 w/sirius and IPOD controllers Code Alarm w/ Remote Start |
Here is a site that has some rear end repair info. http://www.differentials.com/install.html Good luck
with both rear wheels off the ground check for the axle U joints for wear and throwing grease also after driving these joints when bad will get hot... check that the pinion flange is not worn with lateral movement...this where the axle enters the rear diff... then open the rear diff and inspect for metal debris and oil condition... |
