Go Back   Automotive Forums Car Chat > Jeep > Grand Cherokee | Grand Cherokee SRT8
Old 10-09-2008, 09:12 PM
the coop the coop is offline
98 ZJ, I6, 42RE Transmission NEED HELP???
so I found a transmission in a 2001 Jeep Grand Cherokee with the I6 motor, quadratrac, 4 wheel drive and transmission code 42RE, I need to know if it will go in to my 98 with the I6, quadratrac and 42RE with the a bad tranny? If some of the modules/controllers are different can I swap them from my old transmission. If someone ask the symptoms of my transmission before it went out was when it first started in the morning it would wine really bad and even worse when u put into reverse but once you started driving it in forward gears the sound would quiet, it would also rev really high when it shifted from 2nd to 3rd like it was slipping before it totally stopped working. The transmission filter was changed recently and it has fresh fluid at the right level. Thanks for any help you can give!!!
Old 10-10-2008, 05:18 AM
dksob81 dksob81 is offline
Send a message via ICQ to dksob81 Send a message via AIM to dksob81 Send a message via MSN to dksob81 Send a message via Yahoo to dksob81
Re: 98 ZJ, I6, 42RE Transmission NEED HELP???
Yes the transmission for the 01 will work.
R.I.P. - 94 Jeep Grand Cherokee Limited 5.2L V8 Quadra-Trac, 3" Budget Boost, K&N FIPK Gen II (Cold Air Intake), FlowMaster American Thunder (Exhaust).
W.T.T.F. - 1998 Jeep Grand Cherokee 5.9 Limited - Deep Slate Pearl - K&N FIPK GEN II (COLD AIR INTAKE), Altezza Tails and Crystal Clear Front end light with HID Kit and NP242 Swap.
Old 10-10-2008, 03:47 PM
Thanx for the reply dksob81, are you sure? I talked to a salvage yard today and they said it is 98 only for the transmission?
Old 10-10-2008, 04:24 PM
I don't see why it would matter. But let me double check.
