Old 10-09-2008, 09:22 PM
TDWPgtp's Avatar
TDWPgtp TDWPgtp is offline
it was good while it lasted...
today my car was diagnosed with nearly 800 dollars in problems on top of the 1500 just fixed. its also speculated that the supercharger is ready to go. so unfortunately this means that i must sell my car. i know you guys probably dont care but this was my first car, which i love sooo much, and now it must go. its been fun. thanks for all your help with everything everyone. who knows what ill buy next...wont like it tho =(
Old 10-09-2008, 11:19 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Re: it was good while it lastedd...
you just spent 1500 on repairs and now it needs 800 more and your going to sell it rather than fix it? What is wrong with it?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-10-2008, 12:00 AM
Abrasive's Avatar
Abrasive Abrasive is offline
Re: it was good while it lasted...
The dealership is probably quoting you to replace the supercharger. It's generally the only way they will service them, replace only. If you would like, I could put you in touch with a friend of mine that can completely rebuild the SC including the snout, bearings and all, for far cheaper than a replacement. Hate to see you sell the car over repair bills, especially when they are probably higher than they need to be.
Also, if you don't mind, what else did they tell you needed repaired?
2002 Pontiac Grand Prix GTP Sedan - Galaxy Silver, Lowered, GBP Tuned PCM, GBP Ported GenIII Supercharger, Thrasher MPS with 3.4 Pulley, GBP Ported L67 Throttlebody, 1.9 Harland Sharp Roller Rockers, 105# Valve Springs, JMB FWI, PEM's, Shortened Dogbones with Poly Mounts, Triple Edge Performance Transmission with 3.29 gears, F-Body brakes, '05 Bullitt Wheels, lots more. Coming soon: SLP headers, 3.25 Pulley, re-tune.
Master Certified Auto Glass Technician
Old 10-10-2008, 12:15 AM
wlkjr's Avatar
wlkjr wlkjr is offline
Why sell it now when you've almost got everything fixed? Keep till the wheels fall off and you can recoup that money. Mine ain't fell off yet so I think I've gotten my money's worth.
97 Grand Prix GT
360,000 miles as of 02-01-09
391 000 miles as of 11-17-11
400,000 miles as of 3-15-13
01 Duramax/Allison
07 G6 convertible
Old 10-10-2008, 12:18 AM
Highbeamz Highbeamz is offline
I say the dealer never services the S/C to a minimum...they always replace which is costly...
Your supercharger issue could be as simple as a worn coupler (30 bucks from online vendors)...could need a rebuilt snout (200 bucks from ZZP) or better yet for 700 bucks you can get your hands on a Gen V M90...
Don't feel bad. I almost sold my car because it kept making stupid noises (none of which were issues of the drivetrain).
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
Old 10-10-2008, 06:34 AM
TDWPgtp's Avatar
the fuel pump, regulater, and one other small thing(forgot what it was) deffinately need replacing. i thought about a rebuilt sc but i dont know how much longer my tranny will last anyway. and the way things have been goin wrong with this car, its likely something else will go. we just cant risk the money when theres a good chance more will happen.
Old 10-10-2008, 11:36 AM
tblake's Avatar
In God We Trust
the fuel pump and regulator you can replace yourself in your driveway. (or at least I think the 97 mode year has the fuel pummp access cover)
Old 10-10-2008, 12:06 PM
richtazz's Avatar
richtazz richtazz is offline
stupidity should hurt
Many fuel pump issues on GTP's are mis-diagnosed. There is a resistor that controls the low speed operation that many shops aren't aware of. The symptom is that the car will start, run for 3-5 seconds and then die. Fuel pump prime is done on the high speed mode (which by-passes the resistor), then when the PCM switches to low-speed operation through the resistor, the car dies.
Like other stated, the most common issue with the S/C is the coupler in the snout, which is fairly inexpensive to replace. Always remember, all used cars have their issues. At least with this car, you know it's recent history and you have people on here that can help you not get taken when it needs fixing.
Still waiting for the "good old days" I'll get to bore my future grandchildren with!
Old 10-10-2008, 06:52 PM
TDWPgtp's Avatar
Lightbulb Re: it was good while it lasted...
well we considered the price of a new snout and everything if that does happen to go, and im getting the pump and regulator put in with no charge for labor, so we decided to give it another chance. although hesitantly. i hope everything works out in my favor and nothing else goes wrong. thanks for ur input.
ps as far as the resistor goes... the car doesnt shut off after it has started, it just cranks for a few seconds before it does start. the guy at the shop who has had a supercharged 3800 himself before, and i assume knows what hes doing (i hope..ha) said that its lost i think 10 pounds of pressure(dont quote me on that) but he said if it drops any more it could die
