Go Back   Automotive Forums Car Chat > Engineering/ Technical > Tires and Wheels
Old 03-16-2003, 10:11 AM
funkdaflex1 funkdaflex1 is offline
Do I need struts?
I'm considering lowering my car and just getting a set of skunk 2 coilovers. but do i really need to get new struts i have a honda civic if that helps any. I'm just going to be cheap about lowering it cuz it really doesnt matter to me but if i dont have to spend the money im not going to.
Old 03-19-2003, 03:12 PM
Superbeetleman Superbeetleman is offline
It wouldn't be necessary to buy new struts, it would on the other hand be recommended. Unless you like riding around in a car that rides like a covered wagon. If you go any lower than 2 inches your stock struts will crap on themselves. Then the only thing that will be left doing the work would basically be the springs. With the spring rate being so high on coilovers it would be a very ruff and bouncy ride. So in short I would vote you get new, aftermarket , struts. That's my 2 cents. Anyone else have an opinion.
Never underestimate the predictability of stupidity.
Old 04-14-2003, 07:44 AM
viclaster viclaster is offline
I bought a set of KYB AGX adjustable shocks and I have Ground Control Coilovers. I think I will have to buy some new shocks because when I installed the coil over sleeve on the KYB shock I had to hit it with a hammer to knock it down on the shock. With that said I think I damaged the rod of the shock with the hammer banging accidentally against it. I've read that if you scratch or damage the rod, you can have leakage. If that is the case I will buy new shocks.
Do you know of any good shocks that can handle a 3" drop?
I Play to Win. I Win to Win.
Replacing the struts & strut mounts Jmalbright Alero 8 03-15-2010 10:21 AM
Need strut assembly for a 1995 ford contour gl 2.0 dohc what cars would be applicable killer_cr80r Contour 1 04-19-2004 06:13 PM
I Need Struts..... hb4_2000 Tires and Wheels 5 02-06-2002 12:51 PM
Need Strut Brace and Sway Bar DTRsjG20 Classifieds 1 08-23-2001 05:16 AM
Attention: for P10 owner who need struts. Kenny-G Suspension 3 05-10-2001 09:19 AM
