Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 10-09-2008, 04:42 PM
Boris The Blade Boris The Blade is offline
Replacing Pickup Coil...
any proper way to replace the pickup coil on a 93 Burb? i removed the dist/rotor but im stuck there. looks like there is a metal shield/cover over the pick up coil. How do you remove it? does the whole distributor have to be removed? please help. thanks john
Old 10-09-2008, 09:16 PM
2000CAYukon 2000CAYukon is offline
Re: Replacing Pickup Coil...
Yes you need to pull the dist. Then you need to drive the drift pin out of the dist gear with a punch and then remove the shaft.
//2000CAYukon
