Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Engine, Transmission and Drivetrain
Engine, Transmission and Drivetrain Discuss Engine, Transmission, Drivetrain, and all other performance modifications here.
Old 10-09-2008, 01:31 PM
vanilla gorilla's Avatar
vanilla gorilla vanilla gorilla is offline
Timing belt tension
4g64 SOHC.
I check my timing belt tension occasionally, thats why I leave my upper cover off. Anyways, sometimes when I check the tension, there is a iffy amount of play in the belt, then sometimes when I check it, its pretty tight. I guess it just depends on where the cam gear lands.?? Idk.
Anyway. This is the 2nd t belt and 2nd tensioner (oem) I have put on the motor in the last 20k miles. So its not like the parts are worn. I had noticed the variance in tension before....and it bothered me enough that I took the timing belt off and put it back on making sure to tension it properly. Which it still does the same thing. But when I did take it off I made sure to note if the hydaulic tensioner was all the way out, but it had aloooot of way to go actually.
I dont want to take the belt off again, if theres nothing wrong. I mean, theres really no way I can tighten it as long as the auto tensioner still has play left in it.
IDK. Sometimes when i cut the car off its loose, sometimes it tight, so IDK. I have always put the timing system on the same way and I havent lost a motor yet so.
Sorry for writing a novel but what do you guys think?
Caleb
vanilla gorilla
'99 Spyder 2.4 5-speed - Red/black,14b,slow
'96 Eclipse GST 5-speed - Paint
www.myspace.com/ballsoutperformance
Old 10-09-2008, 01:46 PM
LandoAWD LandoAWD is offline
Send a message via AIM to LandoAWD
Re: Timing belt tension
Heat will play a role. Is the car the same temp when you check and it is tighter v. when you check and it is looser?
Kris
2012 Genesis Coupe 2.0t
Old 10-09-2008, 01:47 PM
Didnt take that into consideration, I'll check once the car cools off
Caleb
vanilla gorilla
Old 10-09-2008, 03:07 PM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Took the words out of my mouth. The TB not only produces heat from rubbing in the gears but it's right on the entire engine. I've never checked mine before/after, but I've notice different tensions also. They're made to expand/retract. As long as it actually retracts, you're good.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-09-2008, 04:41 PM
ned032002's Avatar
ned032002 ned032002 is offline
Hypothetically if the engine was ran on a really hot day, could the belt get warm enough to just snap? now I'm curious
Old 10-09-2008, 05:14 PM
inafogg inafogg is offline
IMO,leaving tb cover off only invites problems??i can understand being concered about tension but more so at 50 - 60 k
Live For Today
Yesterday is gone,
Tomorrows are'nt promised.
Old 10-10-2008, 12:51 AM
Thanks for the input guys. Im going to do some more inspection.
And for the kat asking about the TB cover....I only have the upper cover off. I run the upper cover off on my honda too....again for quick inspection.
Caleb
vanilla gorilla
Old 10-10-2008, 07:43 AM
david-b's Avatar
Dave is THAT guy
Hell I have my entire TB cover off. Front, back, top, bottom. Completely gone. No problems yet.
75 Monte Carlo
Old 10-10-2008, 08:40 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
I cut mine so I can get to the cam gears easily to adjust them. The 420a cover doesn't have a removablet top so I just cut it. Dave is more brave than I am running no cover at all..
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
