Old 10-08-2008, 10:22 PM
shawnjohnson66 shawnjohnson66 is offline
Unhappy 1990 Jeep Ignition Inigma
I have a 1990 Jeep Cherokee 4.0, L6, Fuel Injected. I put a new engine in, replaced the computer, Ignition Module etc.. It starts real hard and runs rough, but if I hold the Coil wire about 1 inch from the coil and allow it to arc to the wire, the engine smooths out completely at all RPM's. If I move the wire closer, the engine gets rougher, if I move it farther away it stalls. I also replaced the coil and it made no difference. What the heck could cause this?????
The wires, cap and rotor are all new.
PLEASE HELP!!!
Shawn
Old 10-08-2008, 11:05 PM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: 1990 Jeep Ignition Inigma
Arcing across the air provides resistance to the flow of electricity. Do you have the right plugs in it?
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-08-2008, 11:11 PM
Question Re: 1990 Jeep Ignition Inigma
Well, I got the plugs from Napa when I got the rest of the ignition parts, but it is certainly something to check. I thought about the resistance approach too, but I cannot figure out how to increase the resistance, I have used both high performance and stock wires, the plugs are something I haven't thought about, any suggestions on an approriate plug? I have NEVER ran accross a problem like this before!!!
Old 10-08-2008, 11:16 PM
Yeah, the plugs shouldn't make THAT much of a difference. I had another thought...vacuum hoses. Your engine can run rough if they're not hooked up properly. Check all those, and also your intake and air filter.
Also make sure that your plug wires aren't crossed; I've had some vehicles that were sensitive to that.
Old 10-09-2008, 10:15 AM
Hey Fred, I really appreciate the advice, I'm gonna try chasing the vacuum system, I also heard that the distributer being off a toothe may cause this as the arc could cause a retard in the timing. I'll repost a little later and let you know either way..
Old 10-09-2008, 10:18 AM
Welcome. You're right - timing would also do it.
