Old 10-08-2008, 09:44 PM
panteli2011 panteli2011 is offline
Speaker Help!!!!!
The right rear speaker of my 2003 GT Limited Edition 3.8 L V6 doesnt seem to be working.
I have the bose sound system.
The balance and faders are set right.
I checked the voltage from the speaker wires, the one on the left shows 24 volts when the broken one shows only 6 volts but still no sound coming out.
Trying to remove the speaker to see if its a bad speaker but unable to figure out how to remove them from the rear deck.
Old 10-09-2008, 12:17 AM
Highbeamz Highbeamz is offline
Re: Speaker Help!!!!!
Remove the lower seat (cushion) by pulling on it. Undo the bolts you see there (I think there's 4 or so...i haven't taken them out in a LONG time). You can now slide the seat back up and out. I believe from there you can access/remove the rear deck...but it's been a while since I've done this...I'm sure that's all there is to it. The screws are underneath the deck to pull out the speakers.
2001 Pontiac Grand Prix GTP
14x,xxxkm's
Custom Cold Air Box w/ Airaid filter, Magnaflow Dual Tips, Quantum Tek 106 18" w/ Nexen N3000 rubber, Tinted Headlight Covers, Tinted Tails, Aeroforce Interceptor, 180* T-Stat, 2.5" ZZP Catted DP, Intense PCM, HID Conversion, F+R STB
Old 10-09-2008, 02:00 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
save yourself the trouble and just plug a differnt speaker in place of the bad one just for test purposes.
If the "good" speaker is revieving 24 volts (a little high, maybe you mean mV) from the amp, and the "bad" speaker is only recieving 6 volts (6mV?) then I would almost suspect a burnt out channel on the amp.
You can measure the resistance across the speaker terminals to check for a shorted or open voice coil. Do this with the speaker disconnected. Look for about 4-6 ohms (at least that is what I think most GM speakers are). It should be printed on the speakers magnet.
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-09-2008, 12:06 PM
doctorhrdware doctorhrdware is offline
Some of the time the speaker resistance is not printed on the speaker, but TBlake is correct on what the speaker resistance should be.
Old 10-10-2008, 12:11 AM
Abrasive's Avatar
Abrasive Abrasive is offline
There are little finger loops sticking out from under the rear seat cushion, one on each side. You have to pull these while pulling up on the seat to release the lower portion of the backseat. Simply pulling up on them might break the plastic retainers. GM part number for them is 16809855 if one should happen to get broken, and they are fairly cheap to replace. Just FYI, just in case.
2002 Pontiac Grand Prix GTP Sedan - Galaxy Silver, Lowered, GBP Tuned PCM, GBP Ported GenIII Supercharger, Thrasher MPS with 3.4 Pulley, GBP Ported L67 Throttlebody, 1.9 Harland Sharp Roller Rockers, 105# Valve Springs, JMB FWI, PEM's, Shortened Dogbones with Poly Mounts, Triple Edge Performance Transmission with 3.29 gears, F-Body brakes, '05 Bullitt Wheels, lots more. Coming soon: SLP headers, 3.25 Pulley, re-tune.
Master Certified Auto Glass Technician
Old 10-10-2008, 12:19 AM
Yeah...I haven't pulled them out since last spring....my bad
14x,xxxkm's
Old 10-10-2008, 12:24 AM
Abrasive's Avatar
No problem, I keep one of those retainers handy since I always seem to either pull the finger loop off or break it completley. LOL!
Old 10-11-2008, 01:58 AM
djthechemist djthechemist is offline
Just tap into the channels comming off the amp...
its super easy access, its right on the rear deck in the trunk!
saves you sooo soo much work cuz that rear deck is a jerkkk
but the bose speakers are funny with restances
the subs are 2.2ohm (+/-.2 ohm) and the mids are 4, and well the tweets are 4 and the drivers are 4
with the described situation i would say its the speaker not the amp
my front left driver died... just stoped one day, but the voltage was almost the same, and the resistance was almost the same...its a picky system but at least it doesn't lock out all the speakers in the car!
