Go Back   Automotive Forums Car Chat > Lincoln > Town Car
Old 10-08-2008, 02:54 PM
72mino 72mino is offline
Engine/Tanny removal
Are there any clearance issues with removing the engine/tranny together? I have a Hayne's manual and it only tells how to remove them separately, engine out the top, tranny out the bottom.
I am parting out a 1990 TC that I bought at auction to fix, but decided it would not be worth it.
Dustin
Old 10-14-2008, 07:42 AM
junk yard doggie's Avatar
junk yard doggie junk yard doggie is offline
Re: Engine/Tanny removal
Hello Dustin
These cars part out well. Don't over look the small stuff. The tail light center panels, fuel cut off switch in the trunk, air suspension module, trunk lock cover, trunk pull down motor, power antenna, door pull straps and caps, interior switches, drivers side power seat track, front door hinges, air suspension pump, abs pump, hood ornament, Just to name a few of the hot items.
As far as the engine I try to pull them all together then separate later, I think it makes things easier. I pull the fenders off that makes it a lot easier as well. Lately I've been cutting the frame rails and exhaust pipes just forward of the fire wall and pulling that whole front end section loose engine tans and all. It's a bit extreme but it makes more room on the scrap trucks and trailer with the shortened lincoln. When I separate the engine and trans I'll put the rest of the front frame and suspension in the back of the car. If you want to go to my web site www.cmasalvage.com there is a link at the top that takes you to our e bay store. You can see how I price some of those same items, might be helpful for you.Good luck parting it out Dustin.
Mike aka JYD
