Old 10-08-2008, 01:27 PM
vroom20 vroom20 is offline
Airbag light?
I have a 97 XJ. My airbag light is on and won't turn off. I imagine when I tore my dash apart last year for some A/C work, I triggered this to happen. I have tried to reset it at Midas but it didn't take. They wanted to diagnose it by taking me to the poor house. Naturally, I like to do things myself before sending the work out. Does anyone have insight on why it would be on or what I can do about it?
Old 10-09-2008, 12:00 AM
fredjacksonsan's Avatar
fredjacksonsan fredjacksonsan is offline
Caution: Monkeys bite!
Send a message via AIM to fredjacksonsan
Re: Airbag light?
I'd think that a connection under the dash isn't connected; you will likely have to take the dash out, and make sure it's reconnected.
Ours: 2020 Jeep Wrangler 2.0, 53k
2013 Toyota FJ Cruiser, 84k
Kids: 2005 Honda CRV, 228k
Old 10-09-2008, 03:15 PM
Re: Airbag light?
You are probably right about a bad connection. I am kind of concerned that it might be a mechanical error in the steering column (I have no reason to think this, but just do). When pulling out the dash to check the connections, should I pull the whole thing out like before or can I access all the necessary connection points by removing only some of the plastic?
Old 10-11-2008, 09:54 PM
Re: Airbag light?
I'd be looking at what you worked on earlier....if it's just a couple panels to remove to get at everything, then there's no need to take the entire dash out.
Old 10-11-2008, 10:03 PM
Indy Tech Indy Tech is offline
Re: Airbag light?
Get an ABS scann and Scann for codes you will get to the problem faster
otherwise before you know it you will have the whole dash out again.
indy shop owner/tech
