Go Back   Automotive Forums Car Chat > Ford > Mustang > Mustang Problem Diagnosis
Mustang Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-07-2008, 07:33 PM
1stmaro97v6 1stmaro97v6 is offline
Lightbulb 2001 mustang gt
Hey all, excuse the name ....it was my first car! Here is the problem: One day while i was driving my oil pressure went from normal to low(0) then back to normal then so on till it just stays low. I did change the oil about 2 weeks earlier and when this occured. I changed the oil pressure sending unit, nothing changed. It still registers as low pressure. I drove it thinking that it was a faulty unit untill the knocking began, so it has been parked ever since(about a month) untill i can get it to a shop and pay for repair. I was told by a friend that the oil pump could have went out...the car has 146k miles on it and I have been keeping up with the oil changes. This car is my baby so if there is any one out there with the same problem the advice will be much appriciated. Thanks again.
Old 10-07-2008, 07:38 PM
Lightbulb Re: 2001 mustang gt
Also forgot to mention that after all of this ,that no check oil or check engine light came on.
Old 10-07-2008, 08:59 PM
rhandwor rhandwor is offline
Re: 2001 mustang gt
Buy a manual gage and check the pressure. This is a picture of one.
http://www.autopart.com/tools/toolsmain/tool/T_2001.htm Screw this into the sending unit hole.
If the pressure is good check out the gage. Unplug the sending unit and use a copper wire between it and the gage it should peg. If it don't change the unit in the dash.
If low pressure unbolt the motor mount and pick up the motor and install 4x4's to block up the motor. Be careful and don't break anything. Pull the pan and check for a plugged strainer. I've never heard of a new pump solving the problem without replacing some bearings,but many people try even buy high output pumps. Junkyards always say this but it don't work.
Old 11-05-2008, 04:39 PM
K5Calamity's Avatar
K5Calamity K5Calamity is offline
Re: 2001 mustang gt
Knocking? That's not good. This sound usually occurs when the clearances within your engine have become so great that metallic parts (best examples are rods and crankshaft) can smack together as the engine rotates. This is a dreaded sound and usually = complete rebuild, especially if it resulted from low/no oil pressure.
Another source of knocking is detonation, which is an extreme form of pre-ignition which I don't believe is the cause of your knocking.
