Blower Motor
Problem: I've lost power to the blower motor on all fan settings.
Info: Manual Climate Control - Non Dual Zone The blower motor first went dead, then worked, but it seemed to not be getting the right amount of current then finally stopped working. Motor was not making any adverse noises beforehand. Resistor was changed three years ago. I did have cowel seal leak, but that was repaired back in 2006. I would have expected a blower motor failure back then if water was shorting out the wiring. 1) Are the symptoms listed indicative of a bad blower motor? 2) What is the proper procedure to test the motor? 3) If replacement is needed, is there is write-up on replacement procedures? 4) I see there are several blower motor models. Which is the correct Delco model? Thank you very much for your input.
00' Pontiac Grand Prix GT 83,500 mi |
Re: Blower Motor
All you have to do is remove the passenger side dash kickpanel. Then remove the 3 5.5mm bolts that hold the blower motor up to the HVAC enclosure. Undo the bracket that holds the wiring harnesses and vacuum lines. Undo the blower electrical connector and drop down, replace. Note: Get passenger side seat as far back as possible before starting removal. Quote:
I recall you check the label on the blower to see if you have the 1st or 2nd design blower.
Re: Blower Motor
Most likely, based on your report of the noises from the motor, it is the blower motor, but I've also seen a bad ignition switch cause the motor to not work. But there is usually some other symptoms associated with that such as other accessories not working.
Re: Blower Motor
Re: Blower Motor
Thats true, the only reason I mentioned it is in my GP 1-4 would work just fine, but 5 would not. Then I lost 1-4 and finally had to replace my ignition switch and the blower motor resistor. The blower motor resistor was not fun.
Re: Blower Motor
It probably would be wise to test voltage at the connector before I take the motor out since I was experiencing symptoms of reduced power before the unit quit.
Re: Blower Motor
I wanted to provide an update for those who search this issue later. I pulled the motor out and there was a lot of corrosion on and inside the motor. Replaced it and everything works great.
What I think happened is that when my cowl seal was bad and letting water in the passenger side a couple years ago, water got in the motor, caused the corosion and eventually the unit failed. The install was a PITA of course, but it wasn't that technically difficult.
Re: Blower Motor
Blame the engineer at GM for that making it a PITA to do.Another thing to check is the resistor and they also go out,for burn marks and water spots
Re: Blower Motor
Re: Blower Motor
One thing I've noticed though is that there seems to be quite a bit more vibration in the steering wheel with the new model. It doesn't sound off balance though.
Re: Blower Motor
Hey, on a related topic. My wifes blower motor went out in her 99 GTP (same water leak problem with the crowl which I will fix tomorrow), I replaced it last night but she is only getting heat on the passenger side.
It blows air on both the driver side and the passenger side. The actuator was replaced last year, and I verified that it is working correctly. Does anyone here know what the problem might be? And if so, how I might go about fixing it. I know just enough about her car to keep it from having to go to the shop ALL the time, so if you can explain it in simple terms that would be wonderful too!!! Thanks in advance |
Re: Blower Motor
Re: Blower Motor
She has the digital dual zone.
Re: Blower Motor
