Go Back   Automotive Forums .com Car Chat > Chevrolet > Blazer > Problem Diagnosis
Old 10-06-2008, 09:54 PM   #1
armallard
98' Jimmy v6 vortec 4x4
Didn't really know where to post this but here goes. Is there a away to disable my headlights at night. I know i can set my e-brake and disable them but that keeps me from moving. example: At a boat landing early morning launching my boat and others in line i need to turn my lights off in order not to blind them.
I need some help on this. Any solutions?
armallard is offline   Reply With Quote
Old 10-06-2008, 10:32 PM   #2
ZL1power69
GM S-Series Mod
ZL1power69's Avatar
Re: 98' Jimmy v6 vortec 4x4
With the truck in park, press the dome override button 4 times (in,out,in,out) and you will hear a chime. That disables the AHL and DRL. Repeat that procedure to re-enable those functions.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
ZL1power69 is offline   Reply With Quote
Old 10-07-2008, 09:18 PM   #3
armallard
Thanks for the reply, but no cigar any other ideas?
Old 10-31-2008, 09:24 AM   #4
mudslinger88
mudslinger88's Avatar
on my 01 Bravada I have to press it 6 times before the chime. Keep pressing it until it dings. It still works for me when I'm in gear rolling though. It should also work with the whole Parking brake thing. I usually turn them off every time I drive anyhow because I need to shut them off when I'm going through the sevurity gate at work. Ensure parking brake is set, start engine, press and de-press interior dome light quickly, until you hear a single ding from the dash. It's the same ding you hear when you start the engine, so wait until that series of dings stop. Post back results please. Good luck.
~2001 Oldsmobile Bravada 4.3L Vortech V-6 Automatic AWD~ (Running) (Left hand drive)
~1997 Rover 820Si 1.9L DOHC Inline 4 Automatic FWD~ (Running) (Right hand drive)
~1992 Vauxhall Frontera 2.4L Inline 4 Manual 4WD~ (Running) (Right hand drive)
mudslinger88 is offline   Reply With Quote
Old 11-05-2008, 01:31 AM   #5
fuzzbutt
My '98 only works with the e-brake down enough to turn on the brake light and only if I set it before starting the truck. If it is already running and its dark then the lights are on to stay.
I do have a DRL mod so my DRL's either don't work or my Jimmy does not have them. My green dash light is not on for the DRL's at any time.
fuzzbutt is offline   Reply With Quote
