Old 10-06-2008, 01:12 PM
blind60 blind60 is offline
Location of speed sensors?
99 GMC Sierra 1500
Where would i find the speed sensor that is located in the tranny? Is it for sure in the tanny or is it in the transfer case? I know there are two in the front hubs that have recently been cleaned. I am still having problems with the abs and brake lights coming on during normal driving. these lights will stay on for the remainder of the drive until the truck is turned off. Also still have the problem with the abs kicking on during low speeds.
Old 10-06-2008, 01:30 PM
silicon212's Avatar
silicon212 silicon212 is offline
Confoundingly Lucid
Send a message via ICQ to silicon212
Re: Location of speed sensors?
Your ABS speed sensor will be in the rear differential, also sensors will be mounted on each front wheel assembly. The transmission sensor is for the speedometer and the vehicle PCM.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1!
2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness!
1967 El Camino L79/M20 old school asphalt raper
Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have.
Old 10-06-2008, 01:58 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
If the light is on than there will be a code. Get it and then focus on that part of the ABS system! Overactive ABS can be a broken exciter ring or a speed sensor flakin out. Knowing which one is making the light come on will make finding the problem that much quicker and easier!
Old 10-06-2008, 11:43 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The ABS sensors are located in the rear differential housing and mounted to each front wheel's brake rotor backing plate. The vehicle speed sensor (VSS) is located on the tail housing extension of the tranny, driver's side, where the driveshaft is inserted. On 4wd trucks it is locted in the transfer case.
You don't mention on which axle(s) the ABS is malfunctioning...front or rear only? Both?
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
