Old 10-06-2008, 11:58 AM
BLU CIVIC's Avatar
BLU CIVIC BLU CIVIC is offline
調整器
Send a message via MSN to BLU CIVIC Send a message via Yahoo to BLU CIVIC
b16a1 swap question
alright, looking at getting a B16, mabey, to replace my dead B18a1...now i what can i used from my B18a1 swap if i decided to get this B16? and can i keep my obd0 if i get a PR3 ecu?
The name's Adrian
1990 Civic HB Si - 265.7whp/223tq @9.2psi. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 296.3whp/230tq @1bar. Tuned on NepTune by J.Mills
1991 Civic Sedan DX - 185.8whp/139tq. Tuned on NepTune by J.Mills
2006 G35 Coupe 6MT - Stock
2011 CR-Z - Stock
Old 10-06-2008, 02:40 PM
BLU CIVIC's Avatar
調整器
Re: b16a1 swap question
or better yet, is it possible to get a b18b and make it obd0?
The name's Adrian
2011 CR-Z - Stock
Old 10-06-2008, 06:14 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Just run your B18A1 dizzy and ECU, done.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-06-2008, 08:33 PM
BLU CIVIC's Avatar
調整器
easy enough...same for B20?
The name's Adrian
2011 CR-Z - Stock
Old 10-06-2008, 08:56 PM
Tony's Avatar
TLD Member #1
Basically, its one of the simplest things: The majority of the time, just as long as you stick with the same ECU/Dizzy pair, you can swap it around to run what OBD you need. Ofcourse it won't exactly as intended, but it will run just fine with it. The main time there are complications with doing that is when VTEC comes into play because of the ECU.
Tony
Old 10-06-2008, 09:05 PM
BLU CIVIC's Avatar
調整器
i was thinking that but wasn't too sure
The name's Adrian
2011 CR-Z - Stock
Old 10-06-2008, 10:48 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
You won't have Vtec w/ the B16 if you keep your ECU tho... for clarity.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
Old 10-06-2008, 11:32 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Also your fuel maps wont be right for a b16..but it should run.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-07-2008, 05:38 AM
should run slightly rich... about .2 liters worth of rich.
lacking Vtec, etc... but only until you get the right ECU and dizzy combo for it... and if you're sticking OBD-0, you just get the PR3, and sell the OBD-1 dizz for $75.
Old 10-07-2008, 07:04 AM
BLU CIVIC's Avatar
調整器
i kno i won't have vtec if i keep my PR4 ecu, hence my first question
The name's Adrian
2011 CR-Z - Stock
Old 10-07-2008, 09:52 AM
K, so use the PR3, and use the dizzy from the B18, that will keep it OBD-0.
You won't need to use the dizzy if the B16 you're getting is already OBD-0 tho.
Old 10-07-2008, 09:55 AM
Or you could chip the PR4 and make it Vtec... or you could use a chipped PM6, or you could use the PS9 chipped and use the auto lockup solenoid (A8) for the Vtec solenoid... using the stock maps and only editing that one thing, then throwing some better maps at your topend (after crossover).
In short, you actually have a few options for OBD-0... use whatever one is best for you... probably the PR3 if you can get one readily.
Old 10-07-2008, 02:28 PM
FrodoGT's Avatar
Theres also the pw-0, but thats a jdm ecu and unless your engine comes with it you might not find one. I have seen them for sale and my crx ran one.
Current project:
Rio Red 91 hatch.
Old 10-07-2008, 02:52 PM
Tony's Avatar
TLD Member #1
I love how you guys make it complicated.
Adrian, have you decided which engine you are going for?
Tony
Old 10-07-2008, 03:18 PM
BLU CIVIC's Avatar
調整器
at the moment it's a toss up between 2 different B16's, one that noone will get back to me about, a B18b that i'm waiting on an answer from, and a B18a that is a complete engine...if i get either of those i may end up with my complete B18a sitting in a corner somewhere
The name's Adrian
2011 CR-Z - Stock
