Go Back   Automotive Forums Car Chat > Volkswagen > Jetta/Vento/Bora
Old 10-06-2008, 12:59 AM
feiramb feiramb is offline
Jetta P0501 Speed Sensor
I have a 97 Jetta with a 2.0L and 01M auto that continues to generate a P0501 code. I have replaced the 3 sensors, have checked the wiring harness and grounds, but continue to get the code. I also switched TCMs and speedometer clusters, but neither made any difference. The car works fine except for throwing the P0501 code. Two of the sensors on the transmission seem are the same, but the VW dealer shows the sensors as being different. The problem I have is that the harness has 2-prong connectors for both sensors. The part numbers the dealer is calling for are 095 927 321 C and 01M 927 321 or 01M 927 321 B. Any ideas on why I contiue to get the code?
Old 02-20-2009, 09:42 PM
andeyyy andeyyy is offline
Thumbs down Re: Jetta P0501 Speed Sensor
i have the same problem with the same car(1997 jetta GL M/T). unfortunately this forum is dead and nobody here has answers... try looking at other forums. let me know if anything works. im having a mechanic look at it AGAIN on monday. ill let you know if he figures it out
Old 03-04-2009, 01:25 PM
evo-00 evo-00 is offline
I have a 97 golf with the same code and the speedometer doesn't work. I was looking here for answers but couldn't really find any. So I decided to take out the cluster since nobody was having any luck replacing sensors. I took out the cluster and opened it up. If you look at the back of the cluster you'll see a black round thing about 3/4 of an inch in diameter right behind the speedometer. It just needed resoldered into place and now it works. Hope this helps.
Rich Good
