Go Back   Automotive Forums Car Chat > Volkswagen > Passat > '93 - '96
Old 10-05-2008, 05:48 PM
71 cuda 71 cuda is offline
96 Passat VR6
Just picked up the car. Know nothing about it except owner said it won't start anymore. Put in new battery, radio says "safe", engine turns over. Is there an anti theft mode, ECM, ACM? Any ideas? Car too nice to junk. Thanks Jeff
Old 10-11-2008, 09:40 AM
veedubmechanic's Avatar
veedubmechanic veedubmechanic is offline
VDUBMAN
Re: 96 Passat VR6
There could be many things wrong. Common issue on the vr6 is the timing chains, if the guides failed than the chain skipped a tooth and bent valves. you might have a bad ignition switch, bad ecm, bad antitheft module, ect...
ASE Master certified and VW certified. Just here to help
all check engine light codes ------>
http://www.automotiveforums.com/vbul...d.php?t=328630
