Old 10-05-2008, 12:32 PM
CD Smalley CD Smalley is offline
Pulling to the right under braking....
1997 C1500 2x4.
I just replaced everything on the front brakes since the truck has nearly 200K. I replaced the following:
rotors
calipers
front hoses
pads
bearings
seals
caliper bolts
hose bolts
Pretty much everything. My problem is that I have a slight pull to the right. It will turn the wheel from say 12 o'clock to 1 o'clock when braking without my hand on the wheel and will continue to pull to the right as I stop.
I have bled the system 3 times. No change in the braking pattern.
What am I missing guys?
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Recently updated: http://forums.b-body.org
Old 10-05-2008, 06:13 PM
CoolasIce CoolasIce is offline
Re: Pulling to the right under braking....
Could be:
  • Different tires/air pressure
  • Worn out idler arm, control arm bushing, tie rod arm, or wheel bearing
  • Maybe rear brakes are grabbing unevenly
You're just getting started.
Old 10-05-2008, 06:50 PM
It's done it with two different sets of tires, just had them replaced on Thursday. I did the brakes before that. I think I can rule out tires and tire pressures.
I am ruling our rear brakes since the steering wheel will turn when I brake.
An idler arm is a possibility I suppose except it didn't do this before I started. That would a big coincedence.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 10-05-2008, 07:08 PM
777stickman 777stickman is offline
Some ?'s
1. From you 2nd post, this all started after the front brake job?
2. Were the new rotors turned and finished prior to installation?
3. Make sure that the rotors and pads are "grease & oil free"! (Sorry, that's not a ?)
4. The rebuilt calipers could be suspect also and it could be either side. (Sorry, that's not a ? either)
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-05-2008, 07:34 PM
1 - Correct.
2 - They were new out of the box.
3 - They are. I doused them good with brake cleaner once I was done.
4 - Given it pulls to the right. I suspect the left is weak. Or even the new left hose could be weak.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 10-06-2008, 07:40 AM
Chevy-SS's Avatar
Chevy-SS Chevy-SS is offline
Since you have all new components, I might think about looking at another possibility. That is, the crown in the road you are testing on.
As I'm sure you know, all roads have crowns, that is, the center is higher than the edge. This is done so that water will drain off quickly. The crown in the road is why front end alignment settings are often biased to one side, to compensate for the crown.
Anyway, my point is - if you are testing a perfectly good brake system on a crowned road, it will virtually always pull slightly to the right. A much better test would be to go to a parking lot and try braking in a few different directions. If it pulls to the right at all times, in a parking lot, then you know it's either alignment or brake issue.
1968 427 Camaro SS
1998 Silverado K1500
2004 Corvette Coupe
2011 Chevy Avalanche
______________________
Old 10-06-2008, 08:54 AM
bobss396's Avatar
bobss396 bobss396 is offline
Send a message via AIM to bobss396
I would jack it up and see how easy each side turns. If one is tighter, you probably have a sticky caliper. Which I have seen happen right out of the box. An extremely worn suspension component could do it, but it would be obvious once you shake down the front end.
Bob
Old 10-06-2008, 09:25 AM
Bob,
So do you think it could be the right side sticking? I would have thought given the pull to the right side, that the left was weak....
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 10-06-2008, 10:17 AM
Chevy-SS's Avatar
You won't be able to diagnose strong (or weak) side using hand-rotation of wheels. Both sides will have a little drag. This is perfectly natural for disc brakes. A sticking caliper MIGHT be diagnosed this way, but they usually don't stick all the time.
If you have a sticking caliper, then an easy way to check is to drive truck for a few miles, then bring in - and quickly reach your hand behind each wheel to touch each rotor and see if one is quite a bit hotter than the other. Obviously, the hotter rotor would be the side that is sticking. Of course, be careful as the rotor might be REAL hot. A more accurate method is to measure temp of each rotor using IR (infra-red) temp gauge.
You've installed all new parts and you cleaned the pads and rotors prior to installation. It might be worth spraying everything off one more time with brake cleaner.
I would certainly bleed the brakes again, just to be sure.
Have you tested in flat parking lot?
1968 427 Camaro SS
2004 Corvette Coupe
Old 10-06-2008, 11:58 AM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
1. i'd still rotate front end tires just to be sure it's not them. it's like 10 minute job.
2. you never told us where you got your calipers from. many chain stores sell refurbished parts. that it is shiny from the box does not mean anything. i'd call the store and inquire, unless you had them from dealer, then they are new.
3. did you bleed the master? i understand you had 'front hoses" repalced, so i am assuming you did not touch the metal lines, but assumptions are assumptions.
4. harborfreight tools has digital thermometer for very low cost, the laser one. this might be a much better option to check temp out, instead of reaching with your hand.
good luck.
Old 10-06-2008, 01:15 PM
bobss396's Avatar
I would still jack up the front and see if one takes more effort to turn. One side might get hotter than the other, but you usually get a noticeable burning brake odor with it. But this usually causes a severe pull.
On the side that takes more effort to turn, crack the bleeder and see what happens. You won't be introducing air into the system, so just give it a quick crack and if you get a spurt of fluid, that's the side with the problem. Either the caliper sticks on applying pressure or is not releasing fully.
I've gotten bad calipers before, even have had odd things happening like two different size pistons between the two calipers. Of course the bigger piston will have an increased brake output. But usually you get a sticky caliper that has a cocked piston or scuffed up piston/cylinder wall.
Bob
Old 10-06-2008, 11:27 PM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
I'll throw in the chance that one caliper (the left) is not sliding along its slider bolts as well as it should. I will ask this for clarification...when you brake, does the truck initially jerk to the right but then stop straight after you depress the brake further or does it continue to want to veer right? If the first, then I'd suspect the bolts. If the latter, then I'd suspect the caliper itself.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
Old 10-07-2008, 05:51 AM
It's the later. It jerks the wheel to the right and then continues to pull to the right.
I believe there is something wrong on the left side.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
Old 10-07-2008, 08:26 AM
bobss396's Avatar
It could possibly be a caliper hanging up on the bolts. Your calipers should have come with at least the 4 o-rings in the bolt holes. Some I've seen come with the 2 steel bushings.
At any rate, you should make sure that the bolts are not worn and have been cleaned up. A wire brush is good for this. Then look into the calipers to make sure that the o-rings are square in the bores. If you have possibly pinched one, it could stop the caliper from sliding. I used to run a phillips screw driver shaft around the o-ring to make sure it was seated.
Of course you used brake lube on the o-rings and through bolts? This is essential to make sure things keep sliding for the life of the pads. Also apply brake lube to where the caliper contacts the spindle bracket. Wire brush the mating surfaces first.
Use new steel bushings with every brake job, this is cheap insurance and lube them where they go through on the caliper. I've seen the big o-rings pinched as well.
I hope this helps, I'm sure if one of us were there we could nail it down in about a 1/2 hour.
Bob
Old 10-07-2008, 06:37 PM
New bolts, lube, etc came with the calipers and I used them.
I swapped pads from left to right side as someone mentioned above I think.
That made it better for about 5 stops from 30mph. Then it was right back to pulling to the right.
I went for a drive on a gravel road and did a panic stop from 30mph. It was obvious from the tracks in the gravel the right brake locked up before the left.
I think it must be the left caliper is weak at this point.
CD
1991 W41 #142
1989 Caprice 9C1
1997 C1500
1997 Bonnie SE
1998 Olds 98 LS
