Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Eclipse Problem Diagnosis
Eclipse Problem Diagnosis Got a problem you can't fix? Post here and one of our members will answer as soon as possible.
Old 10-04-2008, 10:31 PM
b18a1civicef b18a1civicef is offline
93 eclipse wont start
i just bought a 1993 eclipse i just put timing belt on it . It has spark gas and air but wont start
Old 10-04-2008, 10:41 PM
Re: 93 eclipse wont start
oh it is the 1.8L non turbo 5 speed
Old 10-05-2008, 10:16 AM
david-b's Avatar
david-b david-b is offline
Dave is THAT guy
Great mad awesome description of the problems and what you checked.
Check your timing to make sure it's not off.
2013 Chevy Sonic 1LZ
75 Monte Carlo
01 Pontiac Grand Am SE - RIP
Old 10-05-2008, 11:30 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Check timing again. If it ran before you changed the belt but now it does not then you probably have the timing set wrong.
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-05-2008, 08:59 PM
well, i bought this car and a 91 laser for 700 bucks. i was told that it just needed the timing set. we set the timing lastnight, that's when i wrote that. sorry the description wasn't the best. thanks, car started today, but it's tapping bad and barely stays running. think it's a bad head, i'll figure it out tomorrow morning.
Old 10-06-2008, 07:32 PM
david-b's Avatar
Dave is THAT guy
Tapping? Like coming from the head? Sounds like the valves are bent from bad timing, which would cause a no/barely run situation like that. Pull the head and check for valve damage and replace whats needed.
75 Monte Carlo
Old 10-06-2008, 09:08 PM
Holset powered 420a
Check compression first. You may not need to pull the head.
98 Eclipse GS Turbo
2001 BMW 325i - DD
