Go Back   Automotive Forums Car Chat > Buick > Century
Old 10-04-2008, 10:14 PM
raycatcher raycatcher is offline
Angry Climate Control Problem
Hello, I have a Buick Century 2000. All summer both of the duel climate controls were set on cold. This past Friday ,it got cold and I moved them both to heat. Drivers side stayed cold-- Passenger side got hot. Now I moved them both back to cold and drivers side stays hot but passenger side gets cold. Any ideas would be greatly appreciated . Thanks, Raycatcher
Old 12-10-2008, 02:56 AM
oldblu65's Avatar
oldblu65 oldblu65 is offline
Question Re: Climate Control Problem
With the automatic climate control , you have a blend door in your system that does the blending of hot and cold air to accomplish your set temperature . This blend door has a motor than gets out of adjustment or fails altogether and doesn't work properly . If you will put this problem into the search feature of this section of the forum , you should pull up posts of possible solutions . Maybe that will help you with your problem . Good luck !
