blue exhaust on startup
Today when i started my car it made a blue cloud of smoke presumingly being oil. My car has never done this before, so what does it mean? I can say one thing though, my battery crapped out yesterday and i started, then turned off my car about 10 times to see how long the battery would last to assure i needed a new one. Do you think this might have to do with the cloud of smoke i saw?
![]() ![]() ![]() '83 Caprice Classic LM1 (truck) 350 swap. about 200HP, 305 ft/lbs..for now. -- 65,000 original miles --
Re: blue exhaust on startup
A bit of oil smoke on cold startup is not unusual on SBC engines. The original valve stem seals quickly harden and don't actually offer a lot of sealing. There is usually very little oil consumed, and it isn't enough to foul spark plugs nor damage the catalytic converter. I'd be surprised if you'll even see a change in oil level between changes due to leaking valve stem seals.
In other words, if the oil is due to leaking valve stem seals, it's not actually a a problem, but merely a nuisance in some cases. It's also a sign that oil is actually reaching the valves and that burning provides a little extra upper cylinder lubrication on cold starts.
Permanent seat assignment on the Group W bench... Automotive Forums Survival Guide |
other causes would be the oil is not draining back into the sump quick enough...head drain holes gooped up, and the valve guides need work, as these engines have a problem here...as manufactured..
If this continues remove the valve cover and inspect for sludge... |
Yeah it hasnt done it since it last did this morning so i think it was just from starting it 10 times one after the other when i was messing with my battery.
That puff of smoke is nothing to worry about. Do worry about it if it doesn't stop smoking for several seconds after the engine is started.
As Blue Bowtie stated, valve stem seal leakage most often causes that puff, it's common on an older engine that uses O-ring seals like the Chevy engines, and will not cause more than a 1-2 tablespoon per 1k mile increase in oil consumption. If the engine only puffs for a second or so, then you won't have to worry about it being anything other than a hardened O-ring stem seal. If the drainback hole in the head plugged, it would smoke a lot more than that.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
You probably had it loaded up from turning it off and on. Personally, I don't trust a small block Chevy that doesn't emit a puff of smoke now and then.
Bob |
its very common to see an older SBC smoke a tiny on start up even if its not every time you start it
older o-ring seals are garbage if you have the disire to do so if the smoke bothers you remove the heads and have them rebuilt but a little oil in the cylinders isn't a bad thing upper cylinder lube hicker-billy style
NO! ,we can't stop here, this is bat country. Raoul Duke |
