Old 10-03-2008, 10:05 PM
dtownfb dtownfb is offline
Help with draining the antifreeze
I was in the process of changing the thermostat on my 2000 Olds Intrigue and had trouble draining the coolant from the engine. I finally got the radiator drain loose (Hint: 1/4 turn to the left and pull at the same time) but could not get the engine block drain loose. I used Liquid Wrench and still could not get the nut loose.
I'll give it another try tomorrow morning but can anyone give me a suggestion on how to drain all the coolant from the engine in case I can't get the engine block drian loose?
Thanks.
Old 10-04-2008, 08:32 AM
Jimmy Olsen Jimmy Olsen is offline
Re: Help with draining the antifreeze
Thanks.
Might try a suction gun inserted via the thermostat opening.
1995 Dodge Ram 1500, 143k miles
1999 Oldsmobile Intrigue, 121k miles
2006 Subaru Forester, 68k miles
Old 10-04-2008, 09:19 AM
Thanks Jimmy. I'll keep that in mind.
Old 10-04-2008, 11:31 AM
tmartin000 tmartin000 is offline
I'm just asking, not telling.
But, isn't it worth the $79 to have a machine do the radiator flush? Oil Can Henry's or Jiffy lube? I mean, does their machine do a good enough job?
I know mine needs it too.
2006 Pontiac Montana
Old 10-04-2008, 09:37 PM
tmartin: After spending about 6 hours playing around with the radiator drain, stripping the engine block drain, struggling with 9 year old clamps and hoses, yes it is better to pay $79 to have someone else flush your cooling system.
I've been trying to learn more about my car and doing the basic maintenance like this. Plus I wanted to try my hand at changing the thermostat. Now that I have experienced it, no need for me to do it again.
I used a hand suction pump to drain the engine block. It actually worked very well. I estimate I only got about half of the coolant out of the engine block but it was very easy to use.
