Old 10-03-2008, 09:00 PM
tiggergal77 tiggergal77 is offline
98 blazer ac won't blow cold
My 98 blazer will not blow cold air when the ac is turned on. The compressor turns on and it has been recharged and filled. Now I have noticed that when the heater is on it will blow hot and then cold and repeat for quite a long time and then eventually stays hot. Any suggestions, thank you.
Old 10-06-2008, 10:58 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 98 blazer ac won't blow cold
Auto or manual controls?
First thing.
Make sure it has good engine vacuum to controls.
Does the compresser run all of the time or cycle on and off?
Does the reciever dryer and low side line feel cold all of the time or go from cold to hot?
MT
Old 10-08-2008, 05:45 PM
It has auto controls I believe. The link below is a picture of it. I don't know if the link will work.
http://http://www.monsterautoparts.c...s/15-72667.jpg
-I bought a controls unit and put it in thinking that might be it and it was not.
-When I got it recharged and filled at Jiffy Lube they found this problem and told me the compressor turns on and off and vaccum was good. They couldn't find why it was doing it. The receiver dryer and low side line I do not know about, I will have to have someone look at it and tell me. I do not know much about vehicles engines.
Thank You so far.
Old 10-08-2008, 07:02 PM
MT-2500's Avatar
AF - Advisor
The auto matic control system can be tester with a ac/heater capable scanner.
But you will need to find a good repair shop to test it.
Let us know how it goes.
Good Luck
MT
Old 10-09-2008, 03:17 PM
Thank You I will do that and let you know.
