Go Back   Automotive Forums Car Chat > Oldsmobile > Silhouette
Old 10-03-2008, 06:37 PM
BOL BOL is offline
97 Olds Silhouette power sliding door won't open
I've performed Diagnostic Mode 1, and it gives the 12 code (no errors). Problem is, it doesn't open. It doesn't open with either button. And it doesn't open with the inside or outside manual pulls.
It acts like it doesn't unlock. But it won't unlock with either the electronic locks, key lock, or key FOB.
I'm at a loss. Can anyone help?
Old 10-06-2008, 09:22 AM
dewaynep dewaynep is offline
Re: 97 Olds Silhouette power sliding door won't open
Sounds like you are right, it is not unlocking. You will have to see if you can get the door panel off and try to manually unlock it.
Old 12-29-2008, 11:29 AM
s.cummings s.cummings is offline
Hi I have the 98 and I would have to pull on the handles 4 or 5 times then you would hear a rolling sound and I could unlock tghe door manually then and open it. Hope this helps
Merry Christmas
Old 12-29-2008, 12:06 PM
BOL BOL is offline
Merry Christmas
Thanks for the reply. I appreciate it. But I ended up selling this van. Because I couldn't ever get that door open!
Thanks again. And happy holidays!
Old 01-06-2009, 11:54 AM
rockwood84 rockwood84 is offline
it probably was dirty contacts on the doorjam panel or the prongs on the door. could have been the lock actuator in the door.maybe a loose wire in the passenger floorboard
Old 01-06-2009, 09:07 PM
roadrunner2 roadrunner2 is offline
I'll bet the child proof lever lock on the sliding door is set to 'lock' and that's why the door won't open.
It's a safety feature used to prevent children from opening the door while the vehicle is in motion.
I have a '00 Silo and have used the lock myself just to see that it actually worked.
The problem with doing nothing is not knowing when you're finished.
Old 01-06-2009, 09:10 PM
One other door lock is the override switch (roof console) for the sliding door.
See if it is set to lockout.
Old 02-03-2009, 04:43 PM
pekoro pekoro is offline
hello, pls try the follow, try to open and close from inside of your car, and be sure that the doohandle goes to the top of the lock, so you can lift the lock button.
pls sorry my english is no very good.
regards
