Old 10-03-2008, 05:19 PM
3000-GTO's Avatar
3000-GTO 3000-GTO is offline
Couple of questions
Alright, first off on the 6 speed when you shift to 6th gear there is supposed to be some resistance if you happen to go to far over to the right. Of course this is to prevent you from accidently going into reverse instead of 6th. My car does this but only for the first 20-30 minutes of driving. After that there is absolutely no resistance when shifting to reverse. This is obviously a bit of a problem whenever I want to shift to 6th gear. Sometimes I will accidently go into reverse and it will grind bad. So I want to fix this ASAP.
Secondly where do you adjust the clutch pedal at? Thanks for the help.
Old 10-03-2008, 06:10 PM
Polygon's Avatar
Polygon Polygon is offline
The Red Baron
Send a message via MSN to Polygon Send a message via Skype™ to Polygon
Re: Couple of questions
I have no clue, but I'd love to hear the answer.
Old 10-03-2008, 06:49 PM
3000-GTO's Avatar
Haha yeah me too.
1995 VR-4: 15G turbos, front mount intercooler, 3sx high capacity radiator, MBC, custom catback, retrofitted HIDs
Old 10-03-2008, 10:28 PM
vectorspecialist vectorspecialist is offline
i've not driven a 6spd 3/s, but isn't 6th right under 5th gear, i wouldn't imagine you having to move the shifter knob over at all, just straight back, usually if there's a lil bit of a change in direction even a direct pull back will work. as for the lockout, i'm not sure
yup, here i am
Old 10-04-2008, 12:51 AM
AutostradaVR4 AutostradaVR4 is offline
becasue after 20-30 minutes of driving, the tranny lube is all warmed up, so it shifts easier. You just notice it more going into 6th because there's usually more resistance.
just a guess...i know my 5-speed gets much easier to shift when it's warmed up. Before my tranny is warmed up, i can't downshift to 1st unless i'm going like 5mph...once it's warmed up though, easy as any other gear. i would suspect it's the same thing.
Formerly BlinkRA182
--VR-4-- --09 Lancer RALLIART-- --Me--
Old 10-04-2008, 01:14 AM
701-3000GT's Avatar
701-3000GT 701-3000GT is offline
on my six speed there is a gate that you pass through to get into reverse,you feel it and its pretty obvious, so you'd have to reeallly be not paying attention to accidently throw it into reverse. but no sixth gear resistance, for mine anyways.
Old 10-04-2008, 03:43 AM
3000-GTO's Avatar
Hmm that's weird I thought that was just a standard safetly feature on the 6 speeds. I wonder if my shifter linkage needs adjustment or something because it is really way to easy to mis-shift.
The thing is it feels like I'm going straight back but somehow ends up in reverse.
Old 10-04-2008, 06:19 AM
maybe when pulling back just pull it a little towards you. or another thing, 6th gear being messed up. you could just not use sixth. everything i read the mpg between 5th and sixth isn't much of a difference on the average ommute to work, just leave the car in 5th
yup, here i am
Old 10-04-2008, 11:28 AM
95DodgeAvenger95's Avatar
95DodgeAvenger95 95DodgeAvenger95 is offline
Send a message via AIM to 95DodgeAvenger95
are u sure ur hitting reverse? maybe ur hitting 6th but ur schrons mite be shot and u could be grinding 6th when really u think its reverse? just a thought.
Black 96 3000Gt Vr4 58k mi, H.H.H. Data logger, RPS MAX, Big16G/14b Combo, FMIC, AEM EUGO, Greddy EBC, SAFC II, 560's, hotwired 255lph, not cats, Solid motor mounts, Faze boost gauge, Apexi turbo timer, full exhaust with 3" ICH Single shot Catback, K&N Air Filter, Front upper strut brace, T-Case Bracket, AC delete, Meth injection, NGK stg 1 colder, 8k HID'S.
AIMING FOR 500+AWHP at ips dyno.
Old 10-04-2008, 11:59 AM
VR43000GT's Avatar
VR43000GT VR43000GT is offline
Send a message via AIM to VR43000GT
I'm with Blink, it just gets easier when your transmission oil warms up as it is a high viscosity oil. My 1st and 2nd gear are definately a little more stiff for the first couple of minutes of driving. After that, it is completey fine. However, you may want to try adding some synchro mesh which from what I have heard others say works very well for smoother shifts when the transmission oil is still cold.
Well, being that it's a hydraulic clutch it self-adjusts but you can also do a manual adjustment on the pedal as well. Lean your driver's side seat back and lay upside-down on it so that you head is where the gas, brake, and clutch pedals are. (Actually kind of comfortable lol) The bar coming through the firewall has a nut on it that allows the pedal itself to be adjusted by loosening the nut and then tightening it back up after your finished. Make sure to leave an inch or two of play in the pedal though.
Old 10-04-2008, 12:58 PM
jason_bet's Avatar
jason_bet jason_bet is offline
Send a message via MSN to jason_bet
If you adjust the pedel Don't move in very much! Also When was the last time you changed your Tranny fluid? check your shift linkage under the hood and make sure nothing is touching or getting in the way of it. How are your motor mounts?
Jason
Old 10-04-2008, 04:45 PM
3000-GTO's Avatar
I am also having a problem shifting to 5th gear it doesn't grind at all but it is very stiff even when the car is warmed up. Sometimes even taking it out of 5th it is stiff it almost feels stuck(has always come out of gear though). So this really makes me wonder if all my problems are just because of the linkage being off.
Jason
Well the fluid should be pretty new I just got a rebuilt transmission in the car 8 or so months ago. Also I have solid motor mounts from 3sx.
