Go Back   Automotive Forums Car Chat > Ford > General Discussion
Old 10-02-2008, 10:59 PM
Guywithface Guywithface is offline
Gas mileage?
I'm new with mechanics and I want to learn more about cars so my question is if the perfect ratio of gas to air is one part gas 14.7 parts air and the throttle controls the amount of air the is taken into the engine then wouldn't driving faster be more fuel efficient?
And why is it that mustangs get 18-20 mpg but honda civics get 40-45 mpg even though they have the same gas to air ratio?
Old 10-03-2008, 07:48 AM
JR Tigerstar's Avatar
JR Tigerstar JR Tigerstar is offline
Re: Gas mileage?
Because Mustangs have more cylinders & bigger engine displacement.
Old 10-23-2008, 05:19 PM
Blt2Lst's Avatar
Blt2Lst Blt2Lst is offline
Re: Gas mileage?
I believe that mustangs are also heavier
opcorn:
1989 Caprice Classic Wagon, Olds 307 ,SMI Q-Jet, 200R4 w/Shift kit, Flowmaster 50, Hotchkiss sway bars, KYB Shocks. Jet Chip,
1989 Mustang LX 5.0 5sp convertible
1992 Camry LE 2.2
1996 Suzuki RMX250
I'm a victim of circumstance [
Old 10-24-2008, 09:08 AM
MagicRat's Avatar
MagicRat MagicRat is offline
Nothing scares me anymore
Re: Gas mileage?
Yes, going very slow is inefficient, but past a certain point, the losses due to the laws of physics means that higher speeds uses more power and thus consumes more fuel than going slower. This happens in 2 ways:
1. Wind resistance goes up with the cube of speed. If you double your speed, the energy lost to wind resistance goes up by eight times. For example if a car requires 10 hp to overcome the wind resistance at 50 mph, then 80 hp is required at 100 mph.
2. The kinetic energy required goes up with the square of speed. If you double your speed, the energy required to accelerate goes up by 4 times. Therefore, a faster-moving car will lose much more energy when it slows down vs a slower moving one. This would not be much of an issue if there were no stops between out starting point and our destination. But the real wold has stop signs etc which use much more fuel for a faster moving car.
Old 10-26-2008, 12:59 PM
carl57 carl57 is offline
Re: Gas mileage?
your question can be answered with power to weight ratios and engine displacements. the civic is much lighter has a 1.5 or so cc engine where as the mustang has between a 4.0 lier to a 5.0 liter engine and is literally built heavier. a mustang is quiter going down the road, developes less body interior squeeks than does the civic and even the interior plastics are heavier constructed. One day maybe the American cars will be mostly carbon fiber shelled who knows.
