Go Back   Automotive Forums Car Chat > Chevrolet > Camaro | Firebird > Engine and Transmission
Engine and Transmission Discuss Engine, Transmission, and all other performance modifications here.
Old 10-02-2008, 10:13 PM
SR34 SR34 is offline
need help 1996 v6 camaro will not start
when i turn the key, it will not crank over it's completely silent.
Old 10-03-2008, 06:08 AM
Genopsyde's Avatar
Genopsyde Genopsyde is offline
The President
Send a message via AIM to Genopsyde Send a message via Yahoo to Genopsyde
Re: need help 1996 v6 camaro will not start
does the "Security" light illuminate on the dash?
Old 10-03-2008, 11:12 AM
the light flashes.
Old 10-03-2008, 01:58 PM
it cranked over 3 times, did not start and now back to silent.
Old 10-03-2008, 02:58 PM
wrightz28's Avatar
wrightz28 wrightz28 is offline
is bring'n sexy back
If you have another key, try it. If not, try cleaning your key and the tangs of the lock cylinder.
Old 10-03-2008, 07:12 PM
thanks i appreciate the help.
it's cranking over now just not starting so it may be the fuel pump ?
Old 10-04-2008, 06:04 AM
Genopsyde's Avatar
The President
spray some starting fluid into the throttle body while cranking. if it fires then dies, you have a fuel delivery problem. if it doesn't fire at all, you probably have a spark problem.
Old 10-06-2008, 10:58 AM
wrightz28's Avatar
Keep fueling them good advice, sparky.
Old 10-06-2008, 03:57 PM
Genopsyde's Avatar
The President
Old 10-06-2008, 04:11 PM
wrightz28's Avatar
I see IQ's have further decreased without my enlightenment.
Play on words, play on words.
Old 10-06-2008, 09:00 PM
Genopsyde's Avatar
The President
those question marks were meant for sr34. im looking for a progress update.
so THERE!!!
Old 10-07-2008, 10:09 AM
wrightz28's Avatar
as you were....
Old 10-07-2008, 04:41 PM
i appreciate your help Genopsyde & i think i need a new fule pump. i don't hear the hum from the pump.
would you happen to know where the fuel pump relay switch is located or is there one?
Old 10-07-2008, 04:46 PM
wrightz28's Avatar
I believe it's in the main power distribution center in the engine compartment.
Old 10-07-2008, 05:15 PM
I'll keep looking and see if I can find it.
thanks
