Old 10-02-2008, 08:59 PM
ceasygt ceasygt is offline
Installed aftermarket head unit....
dic flashes when i turn on the a/c i hear sounds like a relay clicking pls help me on my 02 grand prix
Old 10-04-2008, 08:29 AM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: Installed aftermarket head unit....
Welcome to AF.
To clarify you installed a new radio/stereo system and the problem occurred after installation?
Did you remove head unit and double check the wiring harnesses/connectors especially at the climate control unit?
Timeslip 08/12/06
AF Community Guidelines
Old 10-04-2008, 10:06 AM
tblake's Avatar
tblake tblake is offline
In God We Trust
yeah, but I dont think he would have to remove the DIC or the HVAC controlls to put an aftermarket deck in. Did you cut and splice wires, or use one of them wire harness connectors from wally world?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 10-04-2008, 10:59 AM
i spliced into wire harness i've been pontaic man for years and knew the color code. Maybe i need to put factory unit back in unless you guys can help me
Old 10-04-2008, 11:40 AM
tblake's Avatar
In God We Trust
check to make sure the ground, B+, and accessory are hooked up correctly.
I would just unplug the aftermarket deck and the check the operation of the DIC and HVAC. If it works, chances are you have a wiring problem.
Old 10-04-2008, 11:56 AM
BNaylor's Avatar
I was referring to removing the radio/stereo again not the DIC or HVAC head unit.
He's lost something with the new radio install. Maybe class 2 serial data communications at least associated with the DIC. Is this a standard or enhanced DIC?
Timeslip 08/12/06
Old 10-05-2008, 02:03 AM
i think its enhanched it has 4 buttons on the left side and 2 buttons on the right side. do you thinks a wire harness from wally world would do the trick
Old 10-05-2008, 10:23 AM
tblake's Avatar
In God We Trust
Nope, unfortuanly that ship has sailed.
I think Bob is onto something though. Last radio install I did on a GP I could have swore the radio connector had a data line going to the radio for some reason. Maybe you hooked it up to something it wasn't supposed to be hooked up to by mistake????
What you have to do though is go back inside and check to make sure all the wires are hooked up to where they are supposed to be. You can use this site for reference. Scroll down to "1979-current" vehicles". Any wires that you have that arent listed in this site need to be taped off and not hooked to anything.
http://www.corvetteradios.com/Page.html
Old 10-11-2008, 01:08 AM
djthechemist djthechemist is offline
The factory harness does have a Class 2 data on the 02 GP
but i have never found out what it does because any harness i have ever used never had a pin going to it...
i wanted to believe it had SOMEEE sort of control for the steering wheel controls, but all those wires are located on the red plug along with the amp turn on...
come to think of it..it might actually be for the door chimes?
anyways...
do you have the factory bose system?
