Go Back   Automotive Forums Car Chat > Mercury > Sable
Old 10-02-2008, 03:33 PM
Shay'dtree Shay'dtree is offline
99 Sable 1 cyl not firing
I have a 99 sable that was running rough. I gave it new plugs and wires and air filter and this helped for a short time. It started running rough again so I pulled the plugs to see all were normal except 1. It was soot covered and a little moist. I think I may have valve hanging open. I'm going to have a friend hook up his compression tester to it and see. Would welcome advice on this or other possible causes of these symptoms.
Old 10-02-2008, 06:39 PM
DistanceGuy1's Avatar
DistanceGuy1 DistanceGuy1 is offline
Re: 99 Sable 1 cyl not firing
Hi,
If the "soot" is black and oily, then it is a clear indication of oil consumption and you will need to find out where the oil is coming from -- the pistons and rings, or the valve guides.
