Go Back   Automotive Forums Car Chat > Mitsubishi > Eclipse/Talon/Laser > Exterior and Wheels
Exterior and Wheels This is the place for all exterior wheel modifcations.
Old 10-01-2008, 11:09 PM
vzfox vzfox is offline
Question 1995 Eclipse....LED tail light conversion
Just bought some LED tail lights for my car....they look awsome, but....
The turn signals flash at a high rate of speed. I have done some research on this and found that the flasher module located behind the radio is designed to detect bulb outages and low voltage readings. LED lights emit lower voltage than conventional bulbs, thus causing the "fast flash rate".
By reading up on this, I learned that there is a circuit that needs to be cut or eliminated within the flasher circuit board itself. I have the flasher circuit board in hand.....my question is
What line on the back of the circuit board controls the detection of "bulb outage/low voltage" so it can be eliminated thus having a normal flash rate with LED lights??
Old 10-02-2008, 12:45 AM
SilvrEclipse's Avatar
SilvrEclipse SilvrEclipse is offline
Holset powered 420a
Send a message via AIM to SilvrEclipse
Re: 1995 Eclipse....LED tail light conversion
I read something about this awile back. I beleive if you open up the flasher module there is a wire in there that controls how fast the blinkers flash. The wire puts a certain amount of resistence on the circuit and if you change that value then it will change the rate at which the blinkers flash. I will try and dig something up on it..
98 Eclipse GS Turbo
Megasquirt 2 - Holset HY35 Turbo - Built motor - P&P Head and Intake - 3" Turbo back - FMIC - Greddy RZ BOV - Walbro 255 - Aeromotive AFPR - 650cc Injectors - Fidanza Flywheel - Zoom clutch - 13" Cobra Front Brakes - AEM WB - Devilsown meth injection - 3.55 Final Drive gear ratio
1981 Chevy Scottsdale
1987 Nissan 300zx - Chump Car
2001 BMW 325i - DD
Old 10-02-2008, 12:56 AM
thanx, that would be awsome. As i am sure you are aware, our flasher modules arent like the conventional ones that plug into the fuse box...the 95-99 eclipse's have a rather LARGE flasher box located behind the radio.
Old 10-02-2008, 08:12 AM
Holset powered 420a
Yea I know, here is a link to a guy that converted to LED tail lights and shows how to adjust the flasher rate.
http://www.rcaz.com/rcaz/sub%20index...sher/index.htm
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-02-2008, 12:00 PM
so now I know where to find the wire piece that controls bulb outages and flash rate....only problem is I dont have a soldering iron and I wouldnt know what to put in its place. I guess I was hoping for a simple wire to cut to fix this fast flash rate problem, and since buying a new flasher box seems to be a difficult thing to find and probably expensive at that, i may decide to leave well enough alone and just have the blinkers flash "ghetto style fast".
the link was helpful and much appriciated....i just dont have the tools or knowledge to start "experimenting".
Old 10-02-2008, 12:51 PM
Holset powered 420a
Dude go buy a soldering iron for like 8$ from radio shack and get it fixed. Just experiement with different size wire. Its not going to be that hard.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-02-2008, 01:03 PM
I realize it wouldnt be difficult to do, but I would like to know "exactly" what to do before I start screwing around with something that may end up causing wires to melt or worse. Surely you can understand.
I did try taking a 6 inch piece of wire and wrapping it around the "hoop" to cause more resistance as stated in the link you provided, but that did absolutely nothing. The guy in the link you provided stated that if LED's were used then his fix wouldnt work. He was simply taking stock bulbs out of the circiut.
If I knew I could go down to my local autozone or such and pick up another complete flasher box for $10 or so, then experimenting would be no problem but I cant seem to find our flasher box at any auto store local to me....and I live in a large city (Dallas).
Old 10-02-2008, 05:46 PM
I went down to autozone a bit ago and bought some "load equalizers" specifically made for LED applications ($13). Installed them just as the instructions stated. They got hot as fire, just as the instructions stated they would....but they did absolutely nothing for my turn signal problem. They still blink as fast as they did without them.
Why is it every time I do a "simple" replacement of something, it always turns into weeks of
Old 10-03-2008, 12:00 AM
Holset powered 420a
The reason wrapping that piece of wire did nothing is because you did not change the resistence. Power will always travel the lest restrictive path so unless you force it to go through the wire nothing will change. Here is what I would do. Cut that stock loop out. Measure the resistence of the stock loop and then use something that is slightly high/lower (which ever slows the blinkers down) and see what that does. Keep going lower until you are satisfied with the results. Worst case is that you cant fix it and have to solder the stock loop back in.
98 Eclipse GS Turbo
2001 BMW 325i - DD
Old 10-03-2008, 01:05 AM
Thumbs up Re: 1995 Eclipse....LED tail light conversion
As skeptical as i was, i went ahead and tried your fix. I cut part of the hoop off and wrapped a 9 inch piece of fairly thin speaker wire around the two cut ends of the hoop. Low and behold, the very first try, my blinkers now flash at the normal rate of speed as they did with normal bulbs. I was really surprised that my first attempt at guessing a wire length and thickness was right on. I still dont have a soldering iron (thinking about getting one soon) so I just super glued the wrapped wire onto the cut hoop ends, folded the wire up and put the module back into its square casing. All lights work as they should and now my LED tail lights "really" look awsome.
thanx again "SilvrEclipse".....i never doubted you, i just hate cutting and modifying things that I cant easily replace.
Old 10-03-2008, 06:49 AM
Holset powered 420a
Glad you got it fixed.
98 Eclipse GS Turbo
2001 BMW 325i - DD
