Old 10-01-2008, 09:01 PM
vothman30 vothman30 is offline
Where to ground on Thermostat 88 crx dx
I have a ground that is not where it is suppose to be where exactly is the ground on the Thermostat? Pictures would be great. Or if that is the Ground for the Temp gauge in the car. I believe i have a ground problem just not sure what ground it is the engine or the cluster in the car by the hood pop.
Old 10-01-2008, 09:06 PM
Tony's Avatar
Tony Tony is offline
TLD Member #1
Send a message via AIM to Tony
Re: Where to ground on Thermostat 88 crx dx
No pictures necessary. Look at the thermostat housing, there will be two bolts holding it on. On the bolt on the topside there should be some ground wires, if not, there is your problem.
Tony
91 Civic Sedan DX - Stock 287k Miles
Old 10-01-2008, 09:57 PM
I have heard that there is another place that it goes on the thermostat not on the mounting bolts
Old 10-01-2008, 10:04 PM
Tony's Avatar
TLD Member #1
Its possible, but its just above the mounting bolt. All of them I have seen was on the housing, not hard to find.
Tony
Old 10-01-2008, 10:42 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Bolt it to the thermostat, youll be fine.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 10-01-2008, 10:46 PM
Tony's Avatar
TLD Member #1
Really, its a ground just as long as its coming in contact with metal that some how contacts the chassis, your fine.
Tony
Old 10-01-2008, 11:07 PM
Christ Christ is offline
Send a message via AIM to Christ Send a message via Yahoo to Christ
Some engines used a ground tab that was relocated by the bolt on the thermo housing... others just used the bolt from the thermo housing. That ground wire can actually be placed anywhere in that area, including the starter, if you could make the wire fit around the bolt. It just needs to be on the engine's block, somewhere in that area.
Make sure, wherever you ground it, that you clean that area down to bare metal, clean the contact area of the wire terminal, and add dielectric grease to both surfaces. (Personal preference.)
This will ensure that you have the most effective contact possible.
Honda-free since early 2009.
Current ride: 1996 Ford F150 4.9L (300ci) 5MT 4x4. Rednecks will win.
