99 Taurus 3.0L DOHC - Waterpump Replacement
For those who know, how painful is this job?
Labor Time Standards say 0.9 hrs. Can this be correct?
'97 Windstar 164,XXX '99 Taurus 159,XXX S.E. Michigan |
Re: 99 Taurus 3.0L DOHC - Waterpump Replacement
I own one never have done this job.. looked in my manual, says you have to remove the crankshaft pulley as part of the job. Mabe there is a way around this if you're saying a time of .9 hrs, that's not a lot of time.. someone on here has probably done this.
Checked the Autozone website for repair info, their instructions do not mention anything about crank pulley removal, here's the link;
http://www.autozone.com/addVehicleId...00c1528003a8f2 |
I finished the job this weekend and it took about 5-6 hrs, but I'm slow and could do it faster now that i know what I'm doing.
I didn't pull the crank pulley as this is suggested. This was only done (as best I can tell) to get to the heater hose clamp. I removed the other end of the hose (heater side) and pulled the hose off with the pump. The pump is actually 2 pieces, the housing and the pump. You must remove the housing (4 13 mm nuts), and once off, remove the pump from the housing (7 5mm hex). This took a long time, and I couldn't get one of the nuts (they must use lock-tite). I had to use the dremel and cut it off and use a new bolt. This wasted about 2 hrs. I'd suggest buying the housing & pump together. It looks like rockauto.com sells them this way.
