Go Back   Automotive Forums Car Chat > Dodge > Magnum | Magnum SRT8
Old 09-30-2008, 05:55 PM
collinsrc51 collinsrc51 is offline
Question misfire,rough idle
ive got an 06 magnum 2.7 35,000 miles that will miss sometimes at a low rpm but will smooth out at a higher rpm.but it does not miss all the time.it is also showing a p.0.300 multiple misfire code.i have checked one of the plugs and it doesnt look bad.ive heard about some of these cars that would carbon up the valves and do this,anybody got any ideas. thanx
Old 02-01-2010, 04:39 AM
passnbyu passnbyu is offline
Re: misfire,rough idle
Hi, Mine does the same thing. We had it in the shop and they told us it was carbon build up in the valves. I ran fuel injector cleaner thru and it keeps the check engine light out for a couple of weeks but sooner or later it comes back on. I changed the plugs and that didn't help. When I had the intake off (you have to pull it to change the right side plugs) I took a fiber op. camera and looked down the valves. They looked spotless. Even the ports in the heads looked great. No build up. If you find out whats doing this I would like to know.
Thanks Passnbyu
Old 02-04-2010, 11:53 PM
hundahunta hundahunta is offline
normal there is a tsb for this problem...
Old 02-05-2010, 01:49 PM
spunbearings's Avatar
spunbearings spunbearings is offline
http://www.obd-codes.com/p0300
I'm just curious does anyone have a california emissions car? It should say on a sticker on the top of the radiator support.
Old 02-08-2010, 05:01 AM
Hi, What do you mean that tsb is the problem? Thanks passnbyu
Old 02-16-2010, 02:15 PM
technical service bulletin
Old 02-21-2010, 07:32 PM
Where would I find if there is a technical service bulletin on this. I'm sure more than one owner is having the same problem I'm having. I'm leaning towards the TPS (throttle positioning sensor). It seams to stop when I hit the gas. The check engine light is on most of the time now. Always the same code PO300 multiple cylinder misfire.
Any help will be appreciated!! Passnbyu
