Old 09-30-2008, 02:28 PM
Moe Arif Moe Arif is offline
89CivicDX1.5 - Question on fuel
Is it Ok to switch in between high octane unleaded (98) gas, and the regular unleaded gas? Would it harm the engine or fuel system?
Old 09-30-2008, 03:05 PM
FrodoGT's Avatar
FrodoGT FrodoGT is offline
Re: 89CivicDX1.5 - Question on fuel
No but there is no point in doing so..it wont run better at all.
Cheap, Fast, Reliable..Pick two
Current project:
Rio Red 91 hatch.
A6/Z6 build, Hondata S300, Tokico illumina/Ground Control.
"I'd rather run 12's on steelies than 15's on rotas."
Old 09-30-2008, 03:10 PM
Thanks FrodoGT; I know that. I will be doing this only to prepare it to pass the emission test in Toronto, Canada.
Old 09-30-2008, 03:35 PM
FrodoGT's Avatar
Nope, wont hurt it a bit.
Current project:
Rio Red 91 hatch.
Old 10-01-2008, 07:20 PM
pbrizzle86 pbrizzle86 is offline
Send a message via AIM to pbrizzle86
running on to high of an octane of gas can cause drivability problems. not saying it will but i have seen it a couple of times. if the car isnt in need of it, i.e stock there really is no point, it may run worse on it actually an produce more emissions. anyway where do you get 98 octane anyway i have never seen it, all i have seen is 86,87,89,90,92, and 110, it wont harm anything most likely though. dont really see it helping to much though. is your car burning oil or something to make you assume you wont pass?
the best thing you could do is a basic tune up, plugs, wires, cap and rotor and air filter would help you way more than running higher octane gas ecpecially if you dont have an upgraded ingnition system, or running a high compression app. or possibly even some sea foam, or something along the lines of a BG injector and manifold cleaning. i have used the BG system on all of my cars and noticed a huge diffrence in how the car ran and the emmisions it put out, i dont rember the number anymore as its been a while but before and after reading on the 5 gas analyzer where pretty dramatic.
we dont have emmisons here in minnesota, (thank you jesse ventura) and thats a great thing as none of my cars would pass.
Current cars
1990 honda civic dx High Comp mini me
1986 HONDA CRX SI
Need a winter mobile....
