Go Back   Automotive Forums Car Chat > Chevrolet > Caprice
Old 09-29-2008, 09:01 PM
igot95 igot95 is offline
ignition wirers for alarm starter
i have a alarm system with a strter i located my ignition harness its a yellow, orange, red, pink wirers so i connected all my wirers from my alarm strter modual and tryed it the only thing that happened was my acc lights light up and that ding ding noise (like when u put the key in) but the car dosent start after like three dings my acc lights cut off what do i have to do and i already bypassed my vats system do the 95 caprice have 2 ign wirers o yea do i need to install the immobalizer for the car to strt
Old 09-30-2008, 05:29 AM
gatoratoy227 gatoratoy227 is offline
Re: ignition wirers for alarm starter
yeah that may help if thats not installed it won't act right or not even start (like in your case) the immobilizer is there so no one can just get into your car as its warming up and drive off and if its not connecting and sending a signal through every thing it needs to it won't act right at all
NO! ,we can't stop here, this is bat country. Raoul Duke
Old 09-30-2008, 02:00 PM
ok im going to install that so what am i suppose to do with the second ign wire comeing from the remote strter
Old 10-01-2008, 01:51 AM
if you can post a pic of what you're working on i'll be able to get a better idea of whats going on
and if there is a secong wire it may go to a wireless transmitter as i said i'm shooting in the dark here
a pic would deffinently help
Old 10-02-2008, 08:21 PM
what do u want the pic on the immobalizer or my wiring harness in the car
Old 10-03-2008, 09:04 PM
ponchonutty's Avatar
ponchonutty ponchonutty is offline
Go to www.bulldogsecurity.com and look up the wiring info on your car. Double check your wiring and if it looks OK, put the VATS system back the way it was before you touched it, stick the key in the ignition then try to remote start it. If it works, your bypass is messed up.
Silverado Ext. Cab 4x4 z71
Pioneer 4900mp
Orion P6.2 Componet sets front
Orion C63 Coax rear
DirectedVideo 9" all in one DVD with surround
2007 SATURN OUTLOOK AWD XR with full entertainment package
Old 10-03-2008, 09:34 PM
my car starts with the key but not the remote strter so its not the vats
Old 10-06-2008, 10:20 PM
Again if the bypass is messed up, it won't start with the remote starter. That's why you should put the system back to normal and try to remote start it while the ignition key is in the ignition. If it doesn't start then you'll have to double check your ignition wiring or remote starter programming.
Pioneer 4900mp
Orion C63 Coax rear
Old 10-07-2008, 12:26 PM
ok im going to try that
Old 10-07-2008, 04:45 PM
well its wasnt my vats i think i need to install the starter kill relay
Old 10-08-2008, 09:11 PM
What? The starter kill relay is only to disable the starter when the system is armed. Tell me, what brand unit is this???
Pioneer 4900mp
Orion C63 Coax rear
Old 10-09-2008, 07:13 PM
I Got It Kno I Had To Ground The Neutral Wire But Now I Need To Connect The Tach Wire What Is The Ez Way Do I Have To Go Though The Firewall To Get The Tach Wire I Heard Of The Pcm Way But Dont Kno What That Is
