Old 09-29-2008, 07:40 PM
jdanforth jdanforth is offline
Exclamation power steering problems
i have a 1997 silervado,z71 with the 5.7.i lost power steering and put a new pump in.it growled and moaned so i thought i got a bad pump,i put mthe new pump in today and i still have the same problem????where do i go next??? steering box??its the only thing it can be.any help would be greatly appreciated
Old 09-29-2008, 11:44 PM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: power steering problems
They will make a lot of noise until all the air is out of it. You can add an ounce of sea foam motor tune which will help work out the tiny air bubbles.
Old 09-30-2008, 06:47 AM
i will give that a try,as i will also suction all fluid out and replace with new,fluid looks dirty,maybe the sea foam and replacing ALL the fluid will help.thank you for your imput
Old 09-30-2008, 08:17 AM
dewaynep dewaynep is offline
Did you bleed the pump and gearbox after you installed the new pump? You need to put the front end up on jack stands with the tires off the ground and slowly work the steering from lock to lock while watching the fluid level. You can stop moving the wheel when you no longer see bubbles at the top of the fluid.
Old 10-01-2008, 09:18 AM
i found the problem i have had problems like everyone else with steering,being touchy in turns,little play while driving.friday when the steering pump shaft sheered off,i thought it was just a pump issue.so i put a new unit in.the problem was still there.(YES I BLEED THE SYSTEM)so i went back to napa and got another un it and installed it monday.i had good quiet power steering for 30 or so miles,then all hell would break loose.sounded like a ford .so yesterday after really inspecting things,i found that the steering box was allowing presure to build so much that,itr stopped the pump from being able to circlate the fluid.put a new steering box in,bleed the system,and all my problems have gone away,including the lose feeling while cornering.steers like a new truck.thnks to all who posted,to try and help
Old 10-01-2008, 09:30 AM
Airjer_'s Avatar
Thanks for posting the fix. I have replaced a bunch of pumps with sheared shafts and never had a problem with them or anything else. Thats some good info for future reference!
Old 10-01-2008, 06:28 PM
no problem,just thought i would post the update,just to let people no, who are haveing the same problem.or who run into it in the future.kinda wears on you when somethin works but still not working properly.its alot easier to fix things when they are completly broken .people post on here alot ,with there problems,but dont post what they did to fix it. just hope it helps some one,save alittle time.
