Old 09-29-2008, 02:11 PM
eats1963 eats1963 is offline
speedometer cable lubricant
Over the weekend I replaced the instrument cluster in my newly aquired 1996 Windstar. I thought after reading a few posts on here that replacing the unit would have fixed my bouncing needle. Alas, it has not. After reaching speeds of approx. 50MPH, the needle still bounces almost 10MPH in either direction.
Does the speedometer cable need some type of lubrication? If so, what is the recommended lubricant?
Is there anything else that could be causing the needle to behave so irradically?
Old 09-30-2008, 05:47 PM
LeSabre97mint's Avatar
LeSabre97mint LeSabre97mint is offline
Re: speedometer cable lubricant
Eats963
I had to replace the speedometer on my 95 because a bearing in the speedo head had gone out causing the needle to bounce very simular to what you described. The previous owner was told that the bouncing was caused by the lower speedo cable (it's a two piece) binding. I replaced the lower part when I had the heads off doing a headgasket job.
You know....the replacement speedo head could also be bad.
To answer your question.. I would use a lightweight lithuim grease for the speedo cable.
Regards
Dan
Wiswind's Windstar repair pics http://community.webshots.com/album/201931518cScpNK
Photos of my repairs: http://dansautopictures.shutterfly.com/
Check this out:http://threewheelmotorcyclemetro.shutterfly.co
A must read about problems Windstars have: http://www.automotiveforums.com/vbul...d.php?t=672854
95 Windstar 240,000+
98 Windstar 136,000+ 09-25-2008.
85 Dodge 1 Ton Snow mover gas hog
91 Mazda Protege free beater
SW MN
Old 10-13-2008, 02:02 PM
mbrock307 mbrock307 is offline
Originally Posted by LeSabre97mint
Eats963
The best thing to use is regular old bearing grease... the brown stuff that comes in a can. NEVER use graphite! Lightweight lithium may not cause you any problems, but it is not the recommended lube.
Just My 2 Cents
