Old 09-29-2008, 11:20 AM
stb100 stb100 is offline
Gr Carvn Overheats - Fan Not Working
Hi,
I have a 97 Grand Caravan ES 3.8 that seems to have a dead radiator fan. My wife drove this AM and, stuck in stop-n-go traffic, it overheated. Gauge spiked, lites lit up, etc. She pulled over. I came and traded cars, drove it home with no repeat of the above symptoms -- I was rolling the whole time, 15 mile trip. At home, popped hood w motor running and neither of the 2 fans were spinning. A/C was off. Temp gauge whole way home only topped at halfway (whether gauge is hosed, dunno). Radiator is still full of coolant.
Anyway, anyone know the culprit here...new relay?, new fan?, wiring...? Fan look like a bear to replace at 1st glance
THANKS in advance for any input to solve
STEVE in VA
Old 09-29-2008, 11:32 AM
Airjer_'s Avatar
Airjer_ Airjer_ is offline
Re: Gr Carvn Overheats - Fan Not Working
There is a solid state fan relay that goes bad on these a lot. It is located on the driver side near the bumper. Having a scan tool makes it a little easier to figure out if its this, the fan, or the computer. They are available at your local NAPA for about $40.
Old 09-29-2008, 11:45 AM
THANKS. Was just reading about that relay on another site -WikiAnswers.
Wonder if worth it to just replace relay and not spring for scanner. Any idea about relay cost?
Old 09-29-2008, 11:56 AM
Airjer_'s Avatar
Yup!
Old 09-29-2008, 12:23 PM
Spit Spit is offline
Relay is a good call. If you have a test light or a meter you can test for 12 volts at the fan harness connector. If the voltage is there and the fan doesn't run you could have a bad fan. I had to replace the relay on my 97 GC. I also had a 92 with fan problems and there a fusable link (wire) that blew.
Old 09-29-2008, 04:10 PM
Well...bought a new relay at NAPA. Only non-dealer place that had it (38.00 vs 90.00 at dlr--THANKS Airjer)
Installed and tried it. No fans. Shouldn't rad fan be on full-time? Or does teemp need to hit halfway mark on idiot gauge....Turned AC full on and no fan there either. Getting 12V reading at new relay (on outermost pins). [[I admit to being out of my depth here w elecktrisity ]].
Aarggh#@&*
Old 09-29-2008, 04:26 PM
angus10 angus10 is offline
The fans only come on when the coolant reaches a certain temperature. Which is where the coolant temp sensor comes in to play. Just idling in the driveway they may not turn on, take it for a ride and get it good and warmed up
98 Ram 1500 4x4
Flowmaster American Thunder W/super40
Old 09-29-2008, 10:44 PM
Airjer_'s Avatar
And if your a/c is not working (compressor does not engage) the fan will not come on either.
Old 09-30-2008, 09:16 AM
THANKS folks for your right-on-the-mark help. New relay works. Was easier for me to install from above after pulling out air filter box, etc. Fans both work after short drive and idling at 2k rpm to run temp up to halfway on gauge.
HOWEVER... now the Check Engine Soon light is lit and hasn't gone out. Another one from the "stupid question department". How do I get rid of it?
As always, thanks in advance. AND thanks again, Airjer. Yes my Brake light was on because it needed fluid.
Steve in VA
Old 09-30-2008, 09:29 AM
Airjer_'s Avatar
9 times out of ten that will fix it!
Old 09-30-2008, 09:41 AM
Any idea on the "Check Engine Soon" lite???
THNX
Old 09-30-2008, 10:02 AM
Airjer_'s Avatar
Scan it and see what it is.
Your local parts store will probably be able to do this for you at no charge.
Old 09-30-2008, 10:18 AM
Can a simple batterry disconnect/reconnect make it turn off?
THANKS on the scanner tip. Didn't know but, Advance Auto nearby lets you use their scanner for free. Will see what's up.
Old 09-30-2008, 01:43 PM
Answer is YES re: Discon/reconnect neg battery cable to kill Service Engine Soon lite.
Done w/ this beast for awhile I hope.
THANKS again to all
Old 09-30-2008, 03:59 PM
I would suggest that you have the code read before you disco the battery and lose it. For all we know the code is something unrelated to the the fan problems. Auto Zone and Advance Auto both will read codes for free. Knowledge is Power. chances are it's a code telling you that the engine overheated...but why guess and why worry.
Spit
