Go Back   Automotive Forums Car Chat > Chevrolet > Blazer > Performance
Performance Discuss Engine, Suspension, Drivetrain, and all other performance modifications here.
Old 09-29-2008, 09:05 AM
tomkinsa tomkinsa is offline
True Duals or no duals at all?
I wanna put duals on my sonoma but idk what. I have been hearin that if u wanna put duals on a 4.3 that u should go with a one into two muffler. I found a pair but there is no muffler just resonator tips. is that a bad idea?
Old 10-05-2008, 09:24 PM
ZL1power69's Avatar
ZL1power69 ZL1power69 is offline
GM S-Series Mod
Re: True Duals or no duals at all?
If you run true duals on a 4.3, you will loose most of your low end power and torque, even with and x/h pipe. Unless your 4.3 is heavily built, you will not benifit from true duals. If you want the look of dual exhaust, use a single in/dual out muffler (most are 3in/2.5 out). Best setup for a 4.3 with a few boltons would be a single 2.5in with a high flow cat.
2000 Chevy Blazer ZR2
Performance Mods: Numerous
Suspension Mods: Some, but not enough
Exterior Mods: Just Right
1987 Buick Turbo T Dark Red
Low 11 sec sleeper
.030 4.1 block, PT6262E, & other odds and ends....
My Cardomain
Old 04-08-2010, 10:02 PM
michaelcannon88 michaelcannon88 is offline
ok this sounds more up my alley for my exhaust I am looking at a set of headman street headers full length but cant seem to find a y-pipe to go on the ball and socket ends any1 have any idea where i can find an aftermarket 2 1/2" or 3" Inlet and outlet cause I am going 3" all the way out if I can
Old 04-09-2010, 06:48 PM
b1lk1 b1lk1 is offline
Start calling local muffler shops. There are very few actual aftermarket pre-made systems available. None will be made for full length headers and I have yet to even see an aftermarket y-pipe that was not the same as the OEM.
