Old 09-29-2008, 12:12 AM
matt.bandit matt.bandit is offline
Help with sub and amp
I recently bought 12" boxed sony sub and 350watt 2 channel sony amp second hand off the internet.
I installed it and it worked for a small amount of time but now nothing is happening through it.
Anybody got any tips or ideas why it might not be working?
Any assistance would be appreciated.
Thanks
matt
Old 09-29-2008, 06:34 PM
PaulD PaulD is offline
Audio Guy
Send a message via AIM to PaulD Send a message via Yahoo to PaulD
Re: Help with sub and amp
does the amp come on ?
Old 10-06-2008, 12:07 AM
No it doesn't turn on.
When the car is turned off the amp is receiving enough power or when I remove the remote cable when the car is turned on it also is receiving enough power.
Does this mean the remote cable is faulty or something else?
What can I do to help this as it can't turn on without the remote cable?
Thanks
Old 10-06-2008, 04:17 PM
Galuple Galuple is offline
Check all your wiring again. Make sure your ground, power, and remote all work.
Old 10-06-2008, 04:40 PM
the power and ground are fine until the remote cable comes into play.
Does this mean I need a new remote cable?
Old 10-06-2008, 06:12 PM
Audio Guy
take the remote wire off the amp, then just run a short wire from the +12V on the amp to the remote terminal and see if the amp will turn on like that. Do not leave it hooked up like this, if it works it means theamp will be on all the time and will drain your battery.
Old 10-06-2008, 07:01 PM
I tried connect the remote to th 12v+ but it still didn't work.
The voltages increased slighltly but are still low around 5-6V.
The power cable is only 8guage could that be a problem?
It manages to run over 12v through the power cables when the remote isn't connected though.
Thanks
Old 10-07-2008, 05:54 PM
Audio Guy
if the voltage drops that low when you connect the remote up, then the amp has a serious problem
Old 10-08-2008, 04:15 AM
Does that mean its new amp time?
Old 10-08-2008, 05:16 PM
Audio Guy
I think so, without seeing it in person
Old 10-08-2008, 08:30 PM
Ok thanks for the help
Old 10-10-2008, 05:32 AM
ok drama
Bought a brand new fusion amp and I can't get it out of protect mode.
I've tried stripping it back to only power and it seems to be fine but I'm not sure whether its turning on in this state as the light is very faint.
When i put the RCA jacks in it's the same ad then when i put the speaker cables in it goes into protect again.
Any knowledge aout this?
thanks
Old 10-10-2008, 05:43 PM
Audio Guy
the speaker(s) you are attaching to it are either wired wrong, too low of a load or one is blown (shorted).
