Go Back   Automotive Forums Car Chat > Chevrolet > Avalanche | C&K | Silverado | Suburban | Tahoe > Suburban
Old 09-28-2008, 11:17 PM
95 454 95 454 is offline
95 Suburban shocks
Hey guys, I need a recommendation for shocks. This is for a completely stock C2500. I recently replaced all four corners with Gabriel shocks, and now I have a bit more road noise and a stiff ride, especially on the highway. What are the best shocks that are going to give me a nice even ride? This is for on road use only, and it's my daily driver. Thanks in advance.
1995 Suburban C2500, 454, fully loaded, blue on blue, all stock
1996 Camaro Z28 - M6 swap, LE2 H/C/I, Kooks LTs, etc
Old 09-30-2008, 09:37 AM
MT-2500's Avatar
MT-2500 MT-2500 is offline
AF - Advisor
Re: 95 Suburban shocks
Road noise may be in the tires and or wheel bearing.
Are you using over size tires or a lot of air pressure in them?
A real stiff ride could be a defective shock or HD springs.
I would stay with close to the oem type shock that came on it oem.
Did you change tires or do anything else at the time the shocks were replaced?
MT
Old 09-30-2008, 10:30 AM
jdmccright's Avatar
jdmccright jdmccright is offline
The RustBuster
The 2500s were intended for heavier duty service, so they were typically equipped with stiffer shocks, springs, and suspension. My guess is that your setup had worn down to your comfort level and/or to what you consider to be normal. Then replacing them with new units, the truck was restored to its original setup.
You don't mention the type of Gabriel shocks you have...there are different kinds that can give you different results.
Current Garage:
2009 Honda CR-V EX
2006 Mazda 3i
2004 Chevrolet Silverado 2500HD
2003 GMC Envoy XL
2000 Honda ST1100
2000 Pontiac Sunfire
Vehicle History:
2003 Pontiac Vibe AWD - 1999 Acura Integra GS - 2004 4.7L Dakota Quad Cab 4x4 - 1996 GMC Jimmy 4wd - 1995 Chevrolet C2500 - 1992 Toyota Camry LE 2.2L - 1992 Chevrolet S10 Ext. Cab 4.3L - 1995 Honda ST1100 - 1980 Yamaha XS400 - 1980 Mercury Bobcat.
