Go Back   Automotive Forums Car Chat > Mercury > Grand Marquis
Old 09-28-2008, 08:27 PM
drunkmunky68 drunkmunky68 is offline
97 grand marquis coolant in plug holes
I have a 97 grand marquis that started missing and when i was looking for the miss i found coolant in the #3 and #4 spark plug holes. I could not find where it is coming from. HAS anyone seen this or know what to do to fix the prolem thanks TIM
Old 09-28-2008, 09:40 PM
rhandwor rhandwor is offline
Re: 97 grand marquis coolant in plug holes
I think you have a blown head gasket. A radiator shop can do an analysis for you to be certain. I normally use a pressure tester and the gage will pulsate when pressurized with the engine running. If you do it your self take the heads to a machine shop and have them pressure tested. They will shave them if not straight. Use a flashlight and lay flat along the block and look for cracks especially between the cylinders.
Old 09-29-2008, 08:07 AM
way2old's Avatar
way2old way2old is offline
TOKEN HILLBILLY
Look at the heater hose connector on the passenger rear side of the engine. We have had a lot of the intakes crack around that connection and allow coolant to run into the plug wells.
Being way2old is why I need help from younger minds
The sooner you fall behind the more time you'll have to catch up.
HEY Y'ALL--READ THIS
Here are some of our old vehicles for sale.
Old 10-01-2008, 12:12 PM
I was wondering did you pull a plug and notice antifreeze on top of the piston.
Or did you notice antifreeze around the sparkplug?
Old 10-01-2008, 12:16 PM
Scrapper Scrapper is offline
AF Premium User
if it's missing you have head gasket leaking or cracked head or both.do you have white smoke coming out of your exaust?
Old 10-06-2008, 07:50 PM
thanks for the info when i looked at the heater inlet on the intake i did find a crck running down the side .I ordered aneew aftermarket intake from parts to you for$185 thanks again
