93 GTC questions
My 93 Vert has a few problems. First off for some reason the hoses go flat when the car is not in use. I have no dash lights (fuse ok so that does not seem to be the problem) I have headlights so that is not a problem and the seat (power) will not go back or forward but will go up and down
any ideas? |
Re: 93 GTC questions
In order:
- You have too much air in your cooling system. Make sure the radiator is absolutely full and "burp" the system (when it's cold) by squeezing the upper radiator hose to make the air bubble out, then keep filling up the radiator with more antifreeze as needed. You may need a new thermostat and/or radiator cap. - If your illumination lights fuse is ok, then you may simply need to replace all the bulbs in your gauge cluster. However if the rest of your dash has no lights as well (i.e. - radio, climate control switch) you probably have a bad headlight switch. - And either your power seat switch is broken or one of the 3-4 motors under your seat is bad and needs to be replaced or rebuilt.
thanks a lot this has been a great help
No problem
