Old 09-28-2008, 05:20 PM
Zachary Zoomy Zachary Zoomy is offline
Revell Integra Type R
Finished my ITR. some rough edges, but I learn with every model!
Old 09-28-2008, 06:12 PM
psycho raven's Avatar
psycho raven psycho raven is offline
Re: Revell Integra Type R
don`t worry you frist 4 models will be like that, frist don`t use all the paint gloss. buy tape, new paint brush and use to paint the body spray or airbrush and you will see the change. always ask for help, here are good people that like to help
Old 09-28-2008, 06:31 PM
Zubski's Avatar
Zubski Zubski is offline
Good work
Looks like you are improving with every model. #1 thing i learned with my models is Patients!!! Keep us posted with each model and see how you improve
Zubski
Old 09-28-2008, 06:45 PM
not my 4th, I've done over 20. I have good ones and bad ones. this one is in the middle.
Old 09-28-2008, 07:48 PM
xpeed's Avatar
xpeed xpeed is offline
Better than my first model which was the same as yours. I didn't even bother painting it. LOL
Lexus LF-A Roadster Concept with my bodykit design
"Current Projects"
Nismo Kure GT-R - 0% Sileighty/Onevia - 35%/25%, MCR R34 GT-R - 10%, R34 JGTC Xanavi - 30%, JGTC Raybrig NSX - 0%, 2009/2011 WRX STi - 50%/0%, D1GP Kazama S15 - 55%, Toyota Celica - 2%, Calsonic Z Super GT - 0%, Calsonic R32 GT-R Race car - 5%, C-West RX-7 - 40%, Nismo 350Z 5%, Blitz Chaser - 90%.... a lot of unfinished work.
Old 09-29-2008, 11:30 AM
drunken monkey's Avatar
Razor Sharp Twit
first of all, you may not want to use gloss black for everything.
in most cases, what you want is a semi-gloss (or they might call it satin) black.
secondly; slow down...
it isn't a race.
take a little time to take care of any mold lines, and sink marks, anything that shouldn't be there.
take a little time to mask areas before paint and do please have a look through some of the inspiring build threads because that's where the best tips are "hidden".
AF's Guidelines
Read them.
Old 09-29-2008, 05:08 PM
KevHw's Avatar
KevHw KevHw is offline
I think the most useful advice given, as drunken monkey said, is to slow down. It seems you are rushing through everything in order to try and finish it as soon as you can. When you rush you miss details and it's details that help contribute to a realistic model. Slow down your painting and paint carefully, and you'll end up with cleaner lines.
What painting method do you use? From the looks of the hood, it's as if you're brush painting but other parts of the body seem like you spray painted it. Try to invest in a good quality primer and some high-grade wet & dry paper.
I like how the interior looks as though a can of gloss-black was left in the car on a hot day . Last photo looks good.
Old 09-29-2008, 05:30 PM
jano11 jano11 is offline
Buy some IPA and also get lots of patience! The rest will come after it.
Try using different shades of aluminum and silver for the metallic parts, it will hep a lot.
Old 09-29-2008, 05:44 PM
the hood was repainted, but I think I applied too many layers.
I've been using X-1 for the interior and brush painting it in.
I used tamiya masking tape, but even after sealing the edges it still bleeds.
Old 09-29-2008, 08:03 PM
Mojo_stevo's Avatar
Mojo_stevo Mojo_stevo is offline
Try to burnish the edges with a tooth pick. I use this neon green masking tape that I got from an automotive paint place. It's meant for small jobs, so it stretches nice, and burnishes well with out getting "fuzzy" on the edges.
Old 09-30-2008, 08:44 AM
Razor Sharp Twit
another tip.
Buy some acrylic thinner for the little pots of Tamiya paint.
When hand brushing, I always thin the paint before using for the first time.
I also check the consistency of the paint before I use it again as well because well, thinner evaporates. I've never had a pot of paint that I could use straight from the pot without adding thinner.
AF's Guidelines
Read them.
Old 10-05-2008, 08:27 PM
wrexink's Avatar
wrexink wrexink is offline
Send a message via MSN to wrexink Send a message via Yahoo to wrexink
yes i to did this model and all i can say is take ur time because u are new to modeling. and use some flatpaints to along with tape.
http://www.automotiveforums.com/vbul...d.php?t=658151
My MySpace> www.Myspace.com/stuntit
Old 10-05-2008, 08:57 PM
white_R34's Avatar
white_R34 white_R34 is offline
Yes yes to Master drunken monkey you listen one can learn a lot if one slows themselves down a bit. Try not youngling do or do not, (There is no try) you'll get better in time.
Oops I didn't see you down there sorry for running you over!
http://s162.photobucket.com/albums/t248/White_r34/
