Old 09-28-2008, 04:53 PM
windy01 windy01 is offline
Cruise Control Problems
At first my cruise control work intermittently. Sometimes it worked and sometimes it didn't. Now it is out completely. All the lights work and the fuse is OK. What should I check first?
Old 09-28-2008, 07:31 PM
CnlK CnlK is offline
Re: Cruise Control Problems
Check your brake pressure switch. Read the second posting authored by wiswind, might be your problem.
2014 Chevy Equinox 2.4L, 2010 Grand Caravan 3.8L
Old 09-29-2008, 05:45 AM
wiswind wiswind is offline
In fact, this is exactly what mine did when the brake pressure switch was starting to leak.
Moderator for Ford Windstar room only
Links to my pictures, intended as an aid, not a replacement for, a good repair manual.
1996 3.8L Windstar
http://www.flickr.com/photos/4157486...092975/detail/
2003 Toyota Sienna pictures (not much there yet)
http://www.flickr.com/photos/4157486...781661/detail/
Old 10-01-2008, 08:24 PM
AvalonJohn AvalonJohn is offline
Have you noticed any small puddles of Fluid (Brake Fluid) on your driveway or where you park ? If so, it's very likely to be the Brake Pressure Switch, which attaches to the bottom of your Master Cylindar. Takes 10 minutes to repace by the AVERAGE machanic and cost under $ 30 bucks.
Good Luck,
AvalonJohn
Old 10-02-2008, 07:20 AM
The brake pressure switch was exactly the problem. It was a dealer only part but still it only cost $20 and 10 minutes to fix. Thanks to all.
