Go Back   Automotive Forums Car Chat > Pontiac > Montana/Montana SV6
Old 09-27-2008, 05:58 PM
ryanjenna ryanjenna is offline
Acting wierd
I was driving my 2001 montana 3.4l and it stalled.
Started it right back up and a slow idle it stalled again.
Started it right back up again this time on the highway I had no passing gear push the pedal right to the floor and nothing happed the rpms never went up. today stalled 2 x and had passing gear but very very sluggish.
Its not giving any codes.
Im thinking fuel filter anyone have any other thoughts?
Thanks
Old 09-27-2008, 06:21 PM
rockwood84 rockwood84 is offline
Re: Acting wierd
sounds like the fuel filter is almost completeiy stopped up or the fuelpump is on its last go around.the fuel filter is under the driverside sliding door you will need a set of the gm quick connect release tools or you can use a small flat screwdriver to push the clips [one on each side of the connector] back.i would take the front connector loose if gas pours out of the front of the filter then the fuel filter is not clogged.the fuelpump sounds like it is running but is back pressuring and is not holding a constant pressure of around 50 pounds to keep the motor running.
Old 09-27-2008, 08:58 PM
Re: Acting wierd
Thanks for the reply Ill let you know what I find out.
Old 09-28-2008, 12:35 PM
Re: Acting wierd
Ok it showed a code today po172 any ideas?
thanks
Old 09-30-2008, 09:32 PM
big dave's Avatar
big dave big dave is offline
Re: Acting wierd
That is a fuel delivery code if I am not mistaken
Old 10-01-2008, 09:39 AM
Re: Acting wierd
the code reader didn't have a code reference sheet ?
Old 10-01-2008, 01:05 PM
dewaynep dewaynep is offline
Re: Acting wierd
P0172 is a "System Too Rich Bank 1". Since there really is only one bank to the ECM, it could be either side of the engine or both sides. I would first check fuel pressure and bleed off. You may also want to see if the vacuum line leading to the fuel pressure regulator is wet with gas.
Old 10-16-2008, 11:18 AM
Re: Acting wierd
Eveything lead to the mafs so I checked it yesterday and it was on backwards I took it apart and cleaned it.
I call for a price on one 474 dollars (crazy) just curious what they were worth.
Everything is a ok now with the van!! (Knock on wood)
