Old 09-27-2008, 01:38 PM
pbrenn pbrenn is offline
Question 99 pontiac gtp with heat issues
my 99 gtp is blowing out hot air (when therm.is on high) on the passenger side and blowing out cold air on the drivers side...any suggestions?
Old 09-27-2008, 02:39 PM
BNaylor's Avatar
BNaylor BNaylor is offline
Re: 99 pontiac gtp with heat issues
Welcome to AF.
It would help to post which climate control system you have. The automatic digital dual zone (ACC) or a manual dual zone?
Timeslip 08/12/06
AF Community Guidelines
Old 09-27-2008, 08:28 PM
I have the automatic digital dual zone.......
Old 09-27-2008, 09:43 PM
BNaylor's Avatar
It sounds like you may have an issue with the driver's side temperature actuator which controls the blend doors in the HVAC assembly behind the dash. Do you have a service icon displayed the climate control panel? We have a diagnostics procedure you can run on the CJ2 ACC which may help diagnose the issue.
The other thing you can try is disconnecting the battery negative cable with ignition to OFF and then reconnect, ignition to ON and maybe the actuator will re-initialize itself.
Timeslip 08/12/06
Old 09-28-2008, 01:17 PM
so is there a way i can manually open or close this door so i can stop freezing my ass off in the morning?....or another suggestion?...is this an expensive thing to have fixed?
Old 09-28-2008, 06:59 PM
tblake's Avatar
tblake tblake is offline
In God We Trust
Instead of letting it automatically control temp, can you just set it to 90 degrees and the adjust the fan speed and mode to where you want it?
Does this work, or do you still get cold air?
AF "2.0" Community Guidelines
Conservative Victory 2012!!!
Old 09-30-2008, 01:13 PM
yea i tried that...i still get cold air on the drivers side... gonna have to take it in looks like
Old 10-07-2008, 11:44 AM
no heat
99 gtp. would low coolant cause no heat?
Old 10-07-2008, 08:07 PM
tblake's Avatar
In God We Trust
Re: no heat
yes, defenatly.
If coolant is so low the heater core isnt filled, you wont get heat.
You need to find the leak, check the coolant elbows that pass coolant from the LIM to the belt tensioner into the heater core.
Old 10-07-2008, 08:54 PM
BNaylor's Avatar
Re: no heat
pbrenn,
Please try to keep similar issues confined to the same thread. You had an earlier post on this issue so the posts have been merged together. Otherwise all it causes is redundant answers/replies and possibly confusion.
Timeslip 08/12/06
