Old 09-27-2008, 11:07 AM
taillight taillight is offline
98 Silverado steering jerks
Betweem 30 and 55 mph if I make a right or left turn the steering wheel jerks as if something is loose. I have checked all tie rods and steering joints and they are tight. Could this be a problem with the steering wheel speed sensor or powder steering solenoid actuator? Thank You
Old 09-27-2008, 12:17 PM
ukrkoz's Avatar
ukrkoz ukrkoz is offline
Re: 98 Silverado steering jerks
check your idler and pitman.
inner tierods should have no more than .2 inch play on relay rod, otherwise, must be replaced. and it's a tiny amount.
been there, had that, done that.
Old 09-27-2008, 07:34 PM
777stickman 777stickman is offline
Your '98 most likely has the EVO steering sytem. It's just a speed sensitive system that increases steering effort at speed. The most likely cause is the SWSS (steering wheel speed sensor) as you suspect. One way to check is to disconnect the wiring at the back of the power steering pump. If your glitch goes away it is not mechanical.
Do a search in this main forum for EVO sensor, or some derivative of that, for a lot of info on the subject.
57 Chevy 210
65 Olds 442 Convertible (Another one sold)
75 GMC Vandura 3/4 Ton
1999 K2500 Old Body Style Suburban (Gone but not forgotten)
05 Dodge Ram 3500/5.9 Cummins
2012 Toyota FJ Cruiser
Old 10-02-2008, 11:08 AM
I replaced the steering wheel speed sensor and that was the problem. Thank You
Old 10-02-2008, 11:13 AM
Glad you got 'er fixed and thanks for posting back.
57 Chevy 210
