84 Caprice - Electric Choke not opening
I have an 84 Caprice where the electric choke does not open. I recently turned the spring so the choke stay sully open. Car runs fine after warming up. Where is a good place to start checking. I recently put on a rebuilt carb.
Re: 84 Caprice - Electric Choke not opening
Another thing to look at, would be that since it is a rebuilt carburetor, that the choke is properly adjusted. Sometimes it can be so far out that it seems like it's not working.
1988 9C1 - Modified LM1 @ 275HP/350TQ - TH700R4 - 3.08 8.5" Disc Rear - see it at http://www.silicon212.org/9c1! 2005 Crown Vic P71 - former AZ DPS - 4.6 liters of pure creamy slothness! 1967 El Camino L79/M20 old school asphalt raper Remember - a government that is strong enough to give you everything you need, is also strong enough to take everything you have. |
the electrical connector usually needs replacing...at the choke connection .. next is check that the choke pull off diapham is not leaking...if this leaks the pull off is also going to cause this issue..if the pull off is working correctly it should snap back quickly as soon as the engine is started... you may have multiple problems...... good luck |
found this with the dead sea scrolls.. |
